Lexus RX 350 Oil Control Valve - p0012
Old 07-29-16, 08:17 AM
neumansmom
neumansmom's Avatar
Default Lexus RX 350 Oil Control Valve - p0012
HI everyone,
1st post here and I am trying to fix an issue my mom just started to have. She took it to the dealer and the dealer said it was the OCV also known as the VVT. They wanted 780$ to do this replacement...Which to me is expensive when I saw that the part is only 65$. I am not too familiar with these cars, (I have done plenty of work on my own Volkswagen and Mitsubishi) but I just wanted to reach out to see if anyone has tackled this job and what to expect. I tried searching but I could not find an exact issue with the RX350.V6 she has.
Thanks in advance,
Edit: The RX 350 is a 2008
Old 07-29-16, 01:00 PM
80es300
80es300's Avatar
Video for somewhat similar engine... see if it helps
Old 07-29-16, 01:22 PM
neumansmom
neumansmom's Avatar
Thanks for the video, It helps a little. I know I'll be replace the pair of the OCVs.
Once I complete it, I'll throw up a write up on how to do it, and if I get my go-pro working, I'll run through a step by step on the v6 3.5L. It's what I always do on my other forums if a proper write up isn't available. Hoping to get the parts by Monday. .
Old 07-30-16, 03:00 PM
Dresskell
Dresskell's Avatar
Yeah I need to do this as well.
What part number did you find for the OCV's?
Also, if you do put together a writeup that would be great!
Old 08-01-16, 08:01 AM
neumansmom
neumansmom's Avatar
I found the part # on Lexuspartsnow. I don't know the # off the top of my head, but you can find them there.
I plan on doing a writeup once I receive the parts Wednesday. Hopefully it will go smoothly. I located the two OCVs this weekend and I hope this is relatively painless.
Old 01-21-17, 10:21 AM
kyancy
kyancy's Avatar
Did this solve your problem and how did you get it out past wire harness? That's where I am stuck. Thanks
See my pic on thread: https://www.clublexus.com/forums/rx-...-on-rx350.html
garbo
RX - 4th Gen (2016-2022)
385
07-13-20 11:06 AM
SoonerRX
RX - 3rd Gen (2010-2015)
09-04-17 09:11 PM
MarkiAlex
01-16-16 02:36 PM
AL13NV8D3R
01-02-16 03:28 PM
Quick Reply: Lexus RX 350 Oil Control Valve - p0012
