Thumping Noise after Accelerating
Old 07-17-16, 08:16 AM
dyuanda
dyuanda's Avatar
Default Thumping Noise after Accelerating
I tried to record the sound from my car when I faced this issue but I could not get it properly recorded.
The issue I had was some sort of thumping noise after acceleration. For example, when the car was in 2nd gear, I pressed the gas pedal until it reached third gear (heard or felt the shift movement), I did not press the gas pedal yet. After two seconds, I pressed the gas pedal and suddenly I heard thumping noise. Thus, it wasnt smooth.
There would not be a thumping noise if I did not let my foot off the gas pedal when the gear changed to higher one. Is it normal? It has been quite bothering me.
FYI, I lived in Indonesia where there is no Lexus service center or any CBU service center that could read TSIB/TSB.
I found two TSB that may or may not solve my issue:
1. Drone and vibration on acceleration
2. Fuel Tank Shield Rattle Noise
Can you guys advise me if one of the above TSB is indeed related to my issue? Or were there anything else that I should so?
Thank you.
Again, apology if I can't insert some youtube video demonstrating the bugging noise.
Old 07-18-16, 10:41 PM
dyuanda
dyuanda's Avatar
Guys, anybody here care to help?
Thanks
Old 07-22-16, 12:36 PM
mwengineer
mwengineer's Avatar
Default Possible problem thump on acceleration
Check the engine mounts, I had the same problem were two of the hydraulic engine mounts failed and it develops a "play" damaging the other mounts as well. This problem will get worse over time unless the broken or deformed OEM engine mounts are replaced. $$$
Old 07-25-16, 09:57 AM
mandyfig
mandyfig's Avatar
Search "transmission cooler line thump on deceleration" it was actually a recall. It may not be what you are feeling-hearing though.
jivoz123
07-19-17 09:52 AM
rajbertel
07-21-15 09:28 AM
fanchius
RX - 1st Gen (1999-2003)
12-11-11 05:56 PM
rustylexus
03-23-09 02:28 PM
tcd300
Performance & Maintenance
10-17-08 08:14 PM
Quick Reply: Thumping Noise after Accelerating
