Keys stopped locking/unlocking doors.
Old 06-08-16, 06:59 PM
kisik
kisik's Avatar
Default Keys stopped locking/unlocking doors.
Please advice. My wife said that her keys stopped locking/unlocking doors. I checked the keys and replaced the battery just to be sure. No change. Older keys also couldn't unlock/lock the car.
Both keys can start the car and has blinking red LED flushing when any buttons pushed.
Is there a "Remote" button somewhere in a car to allow remote operation?
Many thanks!!!
2007 RX400h 110k mi.
Old 06-11-16, 07:50 PM
numbafree
numbafree's Avatar
does it still start the car (which would be the ecu chip in the key)?
If it still starts the car, then, most likely, for whatever reason you need to reprogram the keys.
This worked for me, I have an 2005.
**Key must be separately cut and (chip in key) programmed by dealer or locksmith to start the car… this procedure will only program the remote buttons on the key**
Driver’s door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
Within 40 seconds:
Close and open driver’s door twice.
Insert and remove the key from the ignition switch.
Within 40 seconds:
Insert the key into the ignition switch and close the driver’s door.
Switch ignition ON and OFF:
Once to program a key remote transmitter code whilst retaining the original codes.
Twice to program a key remote transmitter code whilst erasing the original codes.
Three times to check how many key remote transmitters are currently registered.
Five times to erase all registered codes.
Remove key from ignition switch.
System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of remote transmitters registered.
Within 40 seconds:
Press and hold LOCK and UNLOCK buttons Fig. 1 or Fig. 2 simultaneously for 1.5 seconds.
Within 3 seconds:
Press and release LOCK or UNLOCK button Fig. 1 or Fig. 2 .
System should now lock and unlock vehicle. Once to confirm registration or twice to indicate registration has failed.
Within 40 seconds:
Repeat button procedure to program remaining key remote transmitters.
NOTE: To exit programming mode: Open driver’s door or insert ignition key.
NOTE: A maximum of 4 key remote transmitters can be programmed.
from: http://blog.carandtruckremotes.com/2...fob-alarm-key/
If you need to re-program the immobilizer portion of the key, I can send you the $20 goodie I got from amazon.com which worked like a charm for me.
Stoodo
05-08-13 07:10 AM
Options2k
11-04-12 03:31 PM
xplosiveg
04-06-12 12:14 AM
trademark
SC- 1st Gen (1992-2000)
23
07-10-11 02:02 PM
VQT
08-04-07 03:39 PM
Quick Reply: Keys stopped locking/unlocking doors.
