Check engine light likely cause
Old 05-27-16, 07:09 PM
DennisMik
DennisMik's Avatar
Default Check engine light likely cause
Hi guys. My 2007 RX350 popped the check engine light. Stopped at an auto parts store and read the codes. They were:
P0300 P0301 P0302 P0303 P0304 P0305 P0306
C0215 C1201 C01223
U0073 UI0123 U0124 U0125
I am most concerned with the P03xx codes. Could this be one common part? I'm on the road about 1500 miles from home, any help would be appreciated.
Old 05-28-16, 09:51 AM
DennisMik
DennisMik's Avatar
Tried to continue on our vacation but the engine is misfiring worse than yesterday, but I was able to limp into a Denver Lexus dealer. They are in the process of analyzing the car right now. If they can't fix it today, I will be stuck her till Wednesday.
Old 05-28-16, 12:25 PM
RXGS
RXGS's Avatar
I would check ignition coils, I think those are misfire codes? And the only code out 350 has ever thrown was a misfire on the 6 cylinder which ended up clearing itself. We brought it to the dealer and apparently it's not uncommon for carbon go cause the cel but the car clearing the carbon out on its own I guess.
Old 05-29-16, 07:20 AM
DennisMik
DennisMik's Avatar
The problem turned out to be only an ignition coil, cyl #5 to be specific. I am thankful it wasn't more complicated (and expensive) than that. The fact that it caused 14 different codes makes me wonder about the soundness of Toyota's electrical design.
Jbakyy
12-13-22 10:35 PM
1stLexus
Performance & Maintenance
39
11-17-22 06:49 PM
Shinedown
01-29-15 05:34 PM
McMuffin
11-02-08 05:20 PM
RNDRX
RX - 1st Gen (1999-2003)
06-07-06 04:23 PM
Quick Reply: Check engine light likely cause
