Did The RX go to a timing chain in the RX
Just a quick question... I had a 2004 RX, 150K, gave it to the mother in law... Wish I could get it back.. She's not letting go... I don't blame her.
My daily Driver is a 2001 LS 430 with 220K and still running strong
I am looking for another RX for the wife to drive on those Colorado snowy days to keep the A7 garaged on those days...
Looking for and 2005 / 2008 with under 150K. If the RX did go to a timing chain in the 3.0, what year did it happen. M
Thanks
Steve
Thanks
Steve
Thanks
Steve
Thanks
Steve
myw (05-25-21)
Super Moderator
Chain is noisier, but does not have to be replaced due to wear. Belt has to be replaced at regular intervals (90-100k) to avoid it breaking and destroying the engine.
Thanks, that seems interesting. I am getting curious how noisy the chain could be; I haven't noticed it on my RX
The RX330 is an interference engine. You DONT want to experience a timing belt failure. If you have a 330 with 100k or more on the clock, get it done now. Do the water pump and pulleys while you're in there. Inspect the radiator too, that is a weak spot if it's the OEM version.
I bought my 330 with 175 on the clock. I had every single service record, but no indication of a timing belt or water pump done. I used that as a negotiating tactic and took care of it the first week after buying her.
Thanks
Steve
Thanks
Steve
I just bought an rx400h. She's 2008 and she has a timing belt not a timing chain. According to my dealer, any rx350 past 2008 had a timing chain on the gasoline models. Hybrids are still belts. Anything pre 2008 according to my dealers have timing belts as well.
To clarify:
All 3.3L engines (RX330, RX400H): belt
All 3.5L engines (RX350): chain
Belt needs to be done every 100K. Chains should be inspected occasionally once past 100K, since they do slacken up a bit over time. Typically though, they are maintenance-free.
myw (05-25-21)
goodduck
RX - 4th Gen (2016-2022)
05-29-17 08:25 AM
