2007 lexus rx 140k miles passenger wiper dead
It was raining today and for some reason the passenger wiper can only go up 1/4 of its way. After 1 minute its just dead while the driver wiper works fine.
Anyone with similar problems before?
Both drivers and passengers are connected to the same arm/motor. I bet the black nut at the base of the wiper arm is loose. Raise the wiper arm to remove the spring tension on the bolt try to move it by hand. If it is loose it will be obvious at this point. To fix, position the wiper where it needs to be at the bottom of the windshield and tighten the nut.
