Alarm, noise, Navi problem
Hi All
I have a 2008 RX350.
All is running well until a few nights ago.
When i shut off the engine and pull the key out i hear a constant clicking sound. I dont really know where its coming from but i can kind of pin point it maybe to the windows or door i'm not too sure. I also notice the interior light flickering to the same pattern as the clicking noise.
That's the first problem and i'm not sure if its associated with the second problem.
Second problem - in the middle of the night the alarm goes off! Its the alarm without the horn noise. For some reason i cant switch it off with the fob key. No matter what i do i cant switch it off. So it goes on for about 20 seconds and stops. I just leave the car unlocked after that and it doesnt come back. The alarm noise is coming from the boot....
Third problem Now the navigation screen flickers. Blacks out then the lexus emblem appears then switches back on itself. Any ideas?
I suspect it could be a dying car battery? I'm not expert so just hoping someone could help.
Cheers
Cheers
Just a quick update. Shortly after posting all the lights came on and the car started stallinn. Roadside came and one of the brackets on the battery came loose and kept hitting the positives and negatives on the battery. He fixed it up and tested the battery. Battery is all good now and the sat nav is fine
However the clicking noise and alarm going off is still happening. Not the battery as it was just tested ok so clueless now
