Tail gate lift problems
Old 01-29-16, 02:00 PM
kampels
kampels's Avatar
Default Tail gate lift problems
Hello,
I have a 2005 RX, the tail gate started to act up, first it wouldn’t always work, then I could only lift it manually. I greased the struts and checked the fuse. After doing this it will only lift manually about six inches. The motor seems to be trying to lift the gate and makes a noise, but I’m stuck at six inches! Any advice?
Old 01-29-16, 08:40 PM
LSBen
LSBen's Avatar
Have you ever replaced your rear struts? If not, then that's the culprit
Old 01-29-16, 11:45 PM
litzdog911
litzdog911's Avatar
You need to replace the rear struts. Search this forum for tips on which ones are the best quality.
Old 01-31-16, 09:01 AM
robbyk
robbyk's Avatar
Originally Posted by kampels
Hello,
I had similar problem, local Lexus Dealer replaced the rear hatch's motor, problem solved. Do not know the total cost as it was done under extended warranty.
Old 02-01-16, 09:58 AM
stevies30
stevies30's Avatar
robbyk is right. You need a new motor.
Old 02-01-16, 10:25 AM
jakenbake
jakenbake's Avatar
I would start with the struts. Much cheaper than a motor and very likely the problem.
Old 02-01-16, 10:37 AM
stevies30
stevies30's Avatar
I was having the same problem and replaced the struts which didn't fix the problem. When I replaced the motor it worked perfectly again. If you want new struts, buy them but the motor is the problem
Old 06-07-16, 09:43 AM
arsooner
arsooner's Avatar
06 RX 400h, trys to open (about and inch) then closes. Then an hour or so later opens just fine, dash or keyfob. Motor sounds strong, guessing these are the original shocks. Shocks or motor? Guessing shocks?
Old 06-08-16, 09:02 AM
robbyk
robbyk's Avatar
See my previous post.
Mine would do the same, I know it does not make sense but it was weather dependent. On warm days I could hardly get it to work, when it was relativity cool the rear hatch would work just fine.
What I was told at the dealership is that if you need new shocks the rear hatch would not stay in the up position when opened all the way. Also if your shocks are shot the rear hatch would not work at all, in case you have shocks that closed frozen.
You might want to try new shocks first, much cheaper than a new motor.
Old 06-13-16, 06:15 AM
arsooner
arsooner's Avatar
Thxs, will go the shock route first.
nkt001
07-04-18 04:53 AM
1111GS
05-19-14 09:19 AM
PearlLex
11-08-04 06:10 AM
LophatRX
RX - 1st Gen (1999-2003)
10-16-04 08:23 PM
eddied106
06-08-03 10:33 PM
Quick Reply: Tail gate lift problems
