Potential purchase advice
Hi everyone, new to the forum. Doing a little research for a 2004 RX330 that my wife may want. The link below has all the info and pics but basically It has 160k miles, 2wd and an asking price of $9750.
http://www.rainbowluxuryimports.com/...6/Details.aspx
I've started reading through and search some threads to get an idea of common problems to look for when we go test drive this RX. Leaking ps rack seems to be number one. Any other obvious ones I've missed to lookout for? Also, their price seems to be quite high for the mileage. I'm thinking the dealer gave way less for this on trade in. Any thoughts on the bottom end to start negotiating?
Thanks in advance
Mike
Thanks in advance
Mike
I would offer 8500-9k.
- Leaking rack is biggest. Dealer charges ~1200 to change.
- Make sure timing belt/water pump completed.
- 2004 had radiator issues
- checks struts....they are usually toast by then
- spark plugs changed - sounds simple but the rear 3 are a pain to get to.
All these things give you negotating leverage.
Alchemist got it spot on. With 2wd you may be able to even go a bit lower on your offer. I am in the same place of you, looking at buying an RX in next couple of months. If I do I will be leaving a 02' CRV, the thing is as reliable as an anvil.
For comparison: Last month, I bought this exact same color 2004 RX here in the Chicago area in very good shape. Mine has 102K, AWD, and Nav. I got dealer maintenance records and a clean Carfax, which included timing belt and radiator. I paid $10,500. Without AWD and Nav, and with the miles, I'd put your car closer to $8K, though you are in a warmer climate!
Pay attention to front end rattles, and transmission clunks. Also try to find some proof of oil change history. Some of the higher mileage ones I've seen have quite the sludgy buildup under the valve cover. Good luck.
Does the rack usually leak in a certain spot or just should be fairly obvious if i lay on the ground and look up under there with a light?
Keep in mind you have a major service coming up at 180k miles if the vehicle has been serviced on schedule, this doesn't include Timing Belt/Water pump. Around $1500 and, new struts figure another $1000 if you don't do any of these yourself. I think the asking price is high.
So I found on the forum that Lexus will let you access the service history if you 'join' their website. I think thats super cool! So check out this crazy report from after Hurricane Katrina Landfall:
NON WARRANTABLE OPERATION CODE CHECK ENGINE LIGHT IS ON, DIAG $79.00PL TX CUST RAN TEST GOT EVAP EMISSIONS CODE, VEHICLE WAS UP ON RACK IN SHOP IN N.O. AFTER STORM, SOMEONE BROKE IN AND CUT PIPE BY FUEL TANK TO DRAIN FUEL, CUST ORDERED PIPE FROM US AND REINSTALLED PIPE PLEASE GIVE EST - CODES 440,441,446, WRONG STYLE GAS CAP ON. NO SEALING ACTION FOR EMISSIONS - R/R GAS CAP. PERFORM EVAP PRESSURE TEST TO CHECK INTEGRITY OF EVAP SYSTEM. CLEAR CODES.
Will be going through the rest of the service history to make sure its not a lemon or something like that.
Thanks in advance
Mike
Thanks in advance
Mike
Also check the dashboard for cracks/stickiness. There is a large thread here about that. There is a warranty enhancement from Lexus (basically a free repair) but as the thread lists it can be a long wait.
My parents have an Avalon and their dash just started cracking. I guess thats all part of the same recall. Thanks
