What is this? Sway bar adjustment?
hello all,
We have a 2007 Rx350; My wife said she heard a "clunk" yesterday so i climbed under and looked around and found this bolt/nut adjustment which I'd assume is to be mounted to the sway/traction bar. This is on the passenger rear. You can see that it clearly broke. I am having quite some difficulty in finding out what this part is called, or part number. i hope i can just replaced the "c" shaped object and adjuster opposed to new "rear suspension assembly" which is what I am seeing on other diagrams. Odd thing is i cannot find one that has this "C" shaped object in it.
also, does anyone have an idea on getting the drivers side rear door interior panel replacement? our dog decided to chew on the armrest and now it will have to be upholstered or replaced.
Hard to tell from the pic. Is your AFS light on? If so that may be the linkage for the headlight level sensor. Check this thread for a parts list to repair it:
https://www.clublexus.com/forums/rx-...ing-noise.html
