Lexus RX 350 tire light
There is a toggle switch under the passanger dash. It accidentally gets switched to 2ed. Just make sure it is set on MAIN and the light will go off. Dealership charged me $100 to flip the switch😡
Service advisor should have questioned that when dropping car off. I'm actually surprised Lexus didn't have the "main" sensors programmed in as the 2nd when the car was built to prevent this from happening.
We have a set of snow tires on dedicated wheels with sensors programmed into the 2nd position. Makes the spring/fall swap a breeze.
It is the low tire light. Problem with it stuck on is I never knew if I actually had a low tire. Very annoying. Thought I'd share because I couldn't find anything about this when I searched online. Hope it saves somebody some $$$
We never charge anyone to put it back to main set. I understand charging for diag. But a stupid simple fix like that... I feel like I would be ripping someone off, which they did. That's just ridiculous.
