Wheel Locks
Wheel Locks
Lets say, hypothetically, I lost the key to my wheel locks, does anyone know of a place I can get one without having to go to the $tealership? Also, I will probably try to pick up 4 regular lug nuts as well. I checked the sales threads and the last time someone was selling a set was 8 months ago.
This could not have happened at a worse time. I need to figure out the cause of my belt chirp so that I can replace the correct part because of up coming life changes and other fun, adult stuff. I cannot check any of the bearings without removing the belt. To remove the belt, I need to remove my wheel.
Thank you for your help.
2007 RX 350
2007 RX 350
Is it the factory wheel and lock? If it is you would have to go to dealership to get the key. Unless you break the locks off and buy new locks and key but make sure if it's the factory wheel you would have to buy the shank style lug/lock
2007 RX 350
2007 RX 350
The 4 dollar lug nuts at Autozone seem like good quality.
Admittedly I have no idea what a shank style lug is, but I will keep that in mind when I go to look for new ones. I appreciate this input.
Thank's a bunch. I found the card (I'm glad the previous owner did a better job of keeping their stuff than I did) and got an order placed with McGard. I am going to be upset at myself if I have to pay $15 every time I want to remove a tire. What kills me is that I have a place for everything and put everything in its place. Situations like this are a lot more inconvenient than having to clean up after myself like an adult.
I use that kind of emergency lug nut remover to loose all key nuts and replace with regular ones, it works like a charm with a impact wrench!
Tapered 13/16"
Tapered 13/16"
I have the unfortunate-fortunate experience of losing my wheel lock key on my RX.
Easily found out that with a picture of your lock, McGard will sent it to you for about $17.
Also know that there are only 7 versions of the locks. I found out when my friend Lexus Tech brought home the masters set for McGard. Yes only 7 versions! I bet this fact will invite comments.
Lesson learned, I have removed the locks to my RX and SC.
Nobody knows there are only 7 versions for Toyota and Lexus. Other brands have different locks, say 7 versions as well. The probability of using 1 key randomly selected to unlock a Lexus-Toyota successfully is almost nil.
Also you cannot even get the master keys from McGARD. They are restricted and you have to be bonded to have a set, like a Locksmith, in this case a dealer.
