Sprained Metal Spring Clips That Hold D2S Bulb in Place
Dear All,
I accidentally sprained/damaged the metal spring clip that firmly hold the D2S HID low beam bulb in its socket on the passenger side of my 2004 Lexus RX 300 (UK/Japan - RHD) while attempting to change a bad bulb.
The metal spring clip no longer hold the bulb firmly in place. This has lead to it shaking in-place, auto-levelling problems and the left low beam not aligned.
I tried googling for replacement clips but no luck. See the attached pictures for a better understanding.
Grateful for your help/advice/contributions.
Thank you.
Thank you.
It looks like by removing (or merely loosening) the cross head screw that the spring would come out - and you could either re-bend it or make another out of suitable wire?
(Nice photographs, however)
Thank you NateJG. I did exactly this and was able to reduce the shaking of the bulb to a great extent. It is still not as firm as the other bulb, but much better than before. Thank you.
LS430Owner
01-19-13 07:51 AM
