Throwing money at my problems...
I've had an odd chirping for the last nine months (post here with video of noise further down page: https://www.clublexus.com/forums/rx-...ing-noise.html). I bought a car stethoscope but have realized I have no idea how to use it. In short, I am no further now than I was six months ago with my original post. 120K is around the corner, I do not know what the original owner replaced and figure I should just start swapping out parts for reliability.
I have the following questions or parts I plan on replacing:
- Belt | Probably replace, though it seems tight and the ribbing seems fine. I figure if I have everything out and have to remove the old one, I might as well spend $15 - $25 and not have to worry about it.
- Belt Tensioner | It only makes the sound at idle. One person had the same noise and it was the tensioner.
- Idler | Another person had the same sound, it was the idler (FML). It just sucks that there are two of them. Does anyone know if they are the same part? (https://www.clublexus.com/forums/att...d-it-29526.png)
- Water pump | Another person (Seriously FML) had the same noise and it was their water pump. The only symptom I have that it could be the WP is the noise. There is no dried coolant on it, wet coolant on it, or loss of fluid in the cooling system.
- Thermostat | While I'm there....
- Radiator drain **** | In case I break the other one. I've broken too many of them to not have the part on hand.
Is there anything else anyone can suggest?
Also, the prices I got for all of the above are (before shipping or tax):
- All Lexus/Toyota = 398
- All ACDELCO = 317
- All Dayco = 268
How much better worse is ACDELCO or DAYCO than Toyota OEM?
*all work will be done myself in a stall with a lift.
- All ACDELCO = 317
- All Dayco = 268
What year is your Lexus RX? You might want to look up the work done at Lexus by the prior owner. If you register at the Lexus Drivers website the entire service history, warranty and recall work of your car will be there. You need the VIN to complete the registration.
https://secure.drivers.lexus.com/lexusdrivers/home
if you are referring to accessory belts and not the timing belt. Dayco/AcDelco parts are ok.
If it is the timing belt and associated pulleys and water pump. Toyota OEM or AISIN parts.
Toyota OEM for the thermostat only.
He has a 2007 RX350 and it has a timing chain instead of a belt. Since there is no maintenance record after 60K miles I would change the water pump and the spark plugs that are scheduled for replacement at 120K miles. Also check the condition of brakes and replace the fluid.
Use Toyota Long Life World Standard transmission fluid only.
Sorry typing ahead of my brain. I should have said - Toyota Long Life Coolant. The WS Transmission fluid is listed by Lexus as lifetime. (although many customers don't believe that).
Originally Posted by Neucorp - OP from above link
I chose not to replace any pulley's - just the pump, related o-rings, and the thermostat.
Originally Posted by Me
Has anyone replaced the waterpump pulley (16173-31010) or just the water pump (16100-09441)
While I'm in there, since I don't know how old it is I feel like I should replace the water pump.
If your power steering pump is down and to the rear of the engine compartment as it is on The Wife's '04 RX330, then you might try to snug that up a tad. Her car had a short squeal at startup. I tightened the %$ out of the alternator thinking that was the problem. Discovered the PS pump belt was loose. :Facepalm:
