Another brake light switch dash lights question
Many threads on this subject, however my lights are a little different
When it first happened, on start up, I got all 4, which went away after about 1/4 mile of driving
Next start up I only have the ABS, VSC steady on and the TPS blinking. No "E brake light" lit like before and as others have mentioned.
The dash lights stay on all the time, even when shutting down and re starting. My rear brake lights work normally. Disconnecting the battery for about 30m didn't reset them either.
Lastly, I hooked up my scanner (Actron) and no codes were returned.
Anyone else have the same symptoms and it still turned out to be the switch??
Well, replaced the brake light switch and that wasn't the solution. So, it must be a sensor somewhere that 's causing the lights. For now, I can live with it until I get a OBDII that can read Lexus codes.
BTW, it was a real PITA changing that switch.........that's the last time I'll ever do that !
RWederfoor
GS - 1st Gen (1993-1997)
10-24-11 08:55 PM
