Retracting steering wheel
Old 09-23-14, 06:32 PM
mnoodles
mnoodles's Avatar
Default Retracting steering wheel
Hi there, dose anyone know how to disarm the auto steering wheel function on a 2004 rx330
I would like to stop the wheel from retracting every time I insert and remove the key.
The manual says to contact the dealer . Thanks
Old 09-23-14, 08:18 PM
Rainbird
Rainbird's Avatar
That is what you need to do, "contact the dealership". It one of the settings that can be changed by the dealer using their computer. It's not free.
Old 09-29-14, 08:42 AM
gasconguy
gasconguy's Avatar
You can also buy the fotga mini OBDII thingy from Amazon. That is a setting you could change yourself for $30.
Old 09-29-14, 09:53 AM
smassey321
smassey321's Avatar
I turned mine off with something like this.
http://www.ebay.com/itm/Mini-VCI-16-Pin-OBD2-Diagnostic-Cable-for-TOYOTA-TIS-Techstream-Cable-CD-US-SHIP-/231271649255?hash=item35d8dd4fe7
Old 09-29-14, 01:16 PM
gasconguy
gasconguy's Avatar
Yeah that's exactly what I am talking about. Smassey, what other features were you able to customize? I found my list was pretty small...
Old 09-29-14, 01:23 PM
smassey321
smassey321's Avatar
Here is a list of features you can adjust. http://www.lexus.com/pdf/service/RX400h_LPS.pdf
You can also read OBD codes and do things such as bleed the brakes.
Old 09-29-14, 02:01 PM
ISFWes
ISFWes's Avatar
Default Steering Wheel
If you dont want to spend the money. You can have the memory location all the way forward. That way it wont extend out when you start the car.
Old 09-30-14, 05:19 AM
gasconguy
gasconguy's Avatar
Thanks. I can't see those options for the power back door. I'll look again, but the only place in Techstream to adjust these is under the main menu button "customize settings" right?
Old 10-01-14, 08:04 AM
smassey321
smassey321's Avatar
The power back door is called something like PRD. Poke around and you will find it. I was able to change the setting for mine. It now opens with a quick click rather than holding it 2 seconds.
Old 10-01-14, 09:15 AM
gasconguy
gasconguy's Avatar
I found it, but there were no options to change - you click on it and it opens a list that is blank. Same with "warnings." I wonder what part of the Fotga thing is causing this, whether it's my version of the software or firmware or what...
RR601
06-18-14 02:18 PM
MissyLexxx
SC- 1st Gen (1992-2000)
11-22-10 04:15 PM
ericg
06-23-09 04:57 PM
sping123
07-24-07 08:23 AM
Quick Reply: Retracting steering wheel
