Lighted Rear Door Scuff plate Out
Old 08-06-14, 08:38 PM
solofgreen
solofgreen's Avatar
Default Lighted Rear Door Scuff plate Out
My 2008 Rx 400h has nice blue"neon" lighted scuff plates. One of my rear plates is out . The dealer tells me that the whole scuff plate unit must be replaced and that it it simply not a matter of replacing a light. There is a lighted strip that apparently is the light source. Has anyone replaced the lights without replacing the whole sill of the door? Thanks.
Old 08-06-14, 10:21 PM
jakenbake
jakenbake's Avatar
The dealer is right.....kinda.....The light can be replaced but only if you are technically inclined. It involves a lot of cutting and gluing and soldering. It would also probably be hard to match the blue. If I were you I would just get the whole new scuff plate. A new one costs about $100.00 and is pretty easy to install yourself.
Old 08-07-14, 04:16 AM
kiwi
kiwi's Avatar
its just a light bulb. be careful and take it apart.
get to the bulb and order one off ebay or somewhere else. save the hundred bucks.
if it doesnt match exactly, it shouldnt be a problem. you prob wont notice. or you could change all 4.
Old 08-07-14, 05:02 AM
solofgreen
solofgreen's Avatar
OK two different views. 100 bucks isn't bad, I thought it would be more. It's nice to have that neon blue light up. If it is just a light I'll go for that. I'll start by taking it off. Thanks for the info.
Old 08-07-14, 11:07 PM
jakenbake
jakenbake's Avatar
Well it isn't a light bulb. It's an LED. And the chance that the LED is bad is very VERY slim...When an LED stops working is almost always the circuit board. Regardless of which route you decide to take, you might as well take it apart and try to fix it yourself. Worse case, you break it trying to take it apart and you have to buy a new one anyway.
Old 08-08-14, 05:28 AM
mandyfig
mandyfig's Avatar
This advise is the way to go! If you are patient, you are going to be OK.
Old 08-08-14, 01:13 PM
solofgreen
solofgreen's Avatar
So if it's the circuit board...where is that positioned?
Old 08-08-14, 03:24 PM
jakenbake
jakenbake's Avatar
The LED is soldered directly on the board.
Old 08-08-14, 10:22 PM
solofgreen
solofgreen's Avatar
Great , I give it a go. Thanks a lot.
vapour1207
RX - 3rd Gen (2010-2015)
09-10-14 03:04 PM
BRIANxJDM
GX - 1st Gen (2004-2009)
01-13-10 01:45 PM
RX7 RAGE
IS - 1st Gen (2001-2005)
08-12-08 05:07 AM
vj3
03-12-08 07:07 PM
Qsmooth
11-21-07 01:36 PM
Quick Reply: Lighted Rear Door Scuff plate Out
