RX330 OIL PAN was leaking at the thread area
Old 07-28-14, 11:49 AM
lccubby101
lccubby101's Avatar
Default RX330 OIL PAN was leaking at the thread area
Hi everyone,
I am new here and I had a 2004 RX330 about 133000K miles now, the car has always been at
the same dealership for maintenance/repairs since about 20K (was at another dealer for the first few
services). Last month (June), I found that there were some oil leaking dribbled down on
my garage floor so I asked the dealer to check earlier this month(July) on my 5K maintenance. The service adviser came back to tell me that the oil pan thread was leaking and was due to wear/tear.
I wasn't so sure. I read some posts here that the oil pan should not be a wear/tear item and
possible the last service guy (same dealer) screwed it up. I attached the image below. Any advise is really appreciated. Dealer quoted me $487 to replace.
Regards,
Hank
Old 07-28-14, 01:16 PM
Rainbird
Rainbird's Avatar
Was a new crush washer used on the oil change?
Old 07-28-14, 02:05 PM
lccubby101
lccubby101's Avatar
No, at least to my knowledge,
Old 07-28-14, 02:28 PM
hypervish
hypervish's Avatar
It's possible the dealer cross-threaded the plug and wants you to pay for their mistake.
Old 07-28-14, 02:33 PM
lccubby101
lccubby101's Avatar
They told me that they did not want to touch it. Because the leak was there before I brought the car in this time. I suspected that something must have happened last time the car was serviced.
Old 07-28-14, 02:55 PM
Rainbird
Rainbird's Avatar
If all else fails here is a video to fix it yourself:
Old 07-29-14, 01:44 AM
DOPEPICS
DOPEPICS's Avatar
probably a crush washer
Old 07-29-14, 09:49 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
or try a slightly oversize drain plug?
Old 07-31-14, 01:59 PM
lccubby101
lccubby101's Avatar
Well, the dealer has gone quiet on me and I am now looking for an alternative way to fix it. That is it.
I will no longer go to this dealer for anything.
I am not a DIY guy so any recommendation for good independent mechanics shops in Fremont, CA area?
Any opinion on using after market (cheaper ) part vs Lexus/Toyota part? The car already have 134K miles
Old 07-31-14, 09:55 PM
thomas1
thomas1's Avatar
Try to use Toyota parts as much as possible. By the way the Toyota dealerships are a good alternative. As for the drain plug, I would try the oversized, but since you are not a diy, maybe see if one of your friends can do it for you for a pack of beer.
seanglenn
01-14-15 07:55 AM
dsc07
01-08-14 08:27 PM
jordanko
05-29-13 10:39 AM
MMakoto
RX - 3rd Gen (2010-2015)
20
05-18-13 11:16 AM
roberttran
Maintenance
12-05-03 11:09 PM
Quick Reply: RX330 OIL PAN was leaking at the thread area
