Front parking sensors
Old 03-03-14, 07:55 PM
jakenbake
jakenbake's Avatar
Default Front parking sensors
I am wanting to install front parking sensors on my 2006...However I want them to work like factory sensors and only turn on if I am below a certain speed (say 5 MPH). Is there a wire in the car that will only show positive or negative at slow speed? Maybe I could somehow tap it to the headlights since the AFS only operates with speed? Or the VSS? Any ideas and solutions would be appreciated.
Old 03-04-14, 01:38 AM
spacecraft
spacecraft's Avatar
Do you mean factory sensors in general?
Afaik, they were not available as a factory option, on 2nd gen RX.
Old 03-04-14, 05:58 AM
draco
draco's Avatar
What I saw in a Toyota Kluger that a friend bought (though you guys might call it a Toyota Highlander, was that there was a switch that you would press to turn on/off when parking. I personally would find it annoying in stop start traffic that the thing would beep every time. Note I have been interested in doing this to my car as well.
Old 03-25-14, 05:27 PM
jakenbake
jakenbake's Avatar
@spacecraft - They actually were offered as a factory option on the second gen RX...Just not in the USA. And I don't want the factory sensors, that would be too expensive to install. I want to know how the speed wire works so that I can install aftermarket sensors but have them act like the factory sensors would work.
@draco - the front sensors don't beep at as far of distance as the rear sensors do...The front sensors only start beeping about a foot away from the object it detects. So even in stop and go traffic it would not beep unless you are really REALLY tailing someone.
Old 03-26-14, 03:22 AM
spacecraft
spacecraft's Avatar
Actually, I can confirm you that also here (in Europe) they were not available.
Some 2nd gen RX were indeed delivered with the parking sensors, but it was a dealer installation, not a factory option.
I'm not 100% sure about how the integration (if any) with the rest of the onboard electric system worked, but I suspect they just placed a beeper somewhere, as you would do with any aftermarket equipment....
Not a clue about other markets, like Japan etc.
Old 03-26-14, 08:15 AM
pauljcl
pauljcl's Avatar
I had rear parking sensors installed on my RX350, but recommended the installer to a friend who installed front and rear sensors on his SL550. I also have both front and rear on my BMW335i. As mentioned by a responder to your post, the front sensors are a lot less sensitive than the rear, which makes sense. In fact, it is very rare that they do beep other than when parking close.
I had my parking sensors installed by a car radio/alarm shop. I am sure you can swing by any such shop in your area and get all the info. you might want directly. Good luck!
Old 03-30-14, 10:26 PM
jakenbake
jakenbake's Avatar
OK...Maybe I should be more clear.
Is there a wire that will show ground or positive at slow speeds?
That is really the question I am getting at.
Old 04-08-14, 07:24 AM
alex1372
alex1372's Avatar
Connect it to your brake lights same idea as rear sensors - regardless of the speed you'll activate your sensors by pressing brake pedal - when something is detected it will beep. That's how I have it on mine
Old 04-11-14, 02:05 PM
jakenbake
jakenbake's Avatar
A little update. I was just looking at Cobra's website again, since they make the only parking sensors I have found that work like and work as well as OEM sensors. They modified their parking sensors to be speed sensing for automatic activation/deactivation. YAY!
jaymig2019
CT 200h Model (2011-2017)
06-14-19 12:31 PM
Willt3
11-17-17 02:23 PM
ESh
ES - 5th Gen (2007-2012)
12-12-14 03:26 PM
Bippu147
02-26-13 11:41 PM
TWong350
08-12-09 10:10 PM
Quick Reply: Front parking sensors
