B1S2 o2 sensor location and part number
Old 02-04-14, 06:25 PM
ctravis17
ctravis17's Avatar
Default B1S2 o2 sensor location and part number
I'm new here so please forgive any faux pas
Here's what I got.
Check engine light on, went to Autozone to use OBB11 and coded P0037
I understand that is Bank 1 Sensor 2
I have asked a couple different places and recieved some conflicting info on the part number.
Also, I am having trouble with the location of the sensor.
I was under the impression that B1S2 was after the cat and the connector is located below the drivers seat. When i got the sensor from the dealer it was the one with the short cable 6". That was not the one I expected to get. The one I expected to get connects under the driverside and has a cable approx. 18"
I could really use some help with the proper part number (Denso or Lexus) and a better explanation of where the sensor is located on an RX330
VIN# 2T2HA31U04C001305
Old 02-04-14, 07:17 PM
RX330inFL
RX330inFL's Avatar
Welcome to Club Lexus, ctravis17. Like many topics you might have questions about, this one as been discussed previously and on multiple occasions. You just need to spend some time using the search tools of the forums. Such as:
https://www.clublexus.com/forums/rx-...-location.html
As for Denso, they are the OEM for many parts for Toyota/Lexus. You can cross reference here:
http://www.densoautoparts.com/find-m...icle-selection
Old 02-05-14, 06:17 AM
ctravis17
ctravis17's Avatar
RX330inFL - Thank you for getting back to me and for providing the the links above.
I did try to do my homework and i saw the post linked above but, it left me a little confused.
The member with the issue was originally mistaken about which sensor he was addressing and than he decided to go with a universal. So, no specific location and no specific part number. I have seen the diagram and i can take a good guess at which part is the sensor i need but, I can't be certain.
I was hoping to get confirmation that Bank 1 Sensor 2 = part number xxxx-xxxx
If not using, Denso's terminology Bank 1 Sensor 2 = Downstream Right or Left
None of the dealers or autopart stores in my area have the part in stock and, I don't want to order it and figure out a week later that it is the wrong part.
Old 02-05-14, 07:44 AM
ctravis17
ctravis17's Avatar
Hoping to help the next guy looking for this info:
I found the Denso cutomer service line Customer Service: 1-877-675-5463
Very helpful
2004 RX330
B1S1 = A/F sensor Upstream Right
B1S2 = O2 sensor Downstream Right (this is located below the Cat on the drivers side with the connector on the undercarriage appox. below driver's seat.) Denso part number 234-4509 (locally $130)
B2S1 = A/F sensor Upstream left
B2S2 = O2 sensor Downstream left
Denso Parts site
Installation instructions from Denso
http://services.densoautoparts.com/r...or_BW_DPAM.pdf
Old 04-18-14, 04:02 PM
lexrod6
lexrod6's Avatar
Very helpful
2004 RX330
Denso Parts site
Great info! Was this a difficult DIY? I just ordered the part based on your input for B1S2.
So, just to be clear - the connector and plug are both accessed from under the car?
Thanks so much.
Old 03-19-16, 07:31 AM
crosborne
crosborne's Avatar
Very helpful, thanks
I always hate "use the search function" type answers. Why, because the search feature sux.
BTW, http://lexus.sewellparts.com/oem-cat...X330-2006.html is dead now, so the info ctraivis17 posted is perfect.
Very helpful
2004 RX330
Denso Parts site
Old 03-19-16, 09:11 AM
crosborne
crosborne's Avatar
Default 2004 Lexus RX330 O2 sensors
Here is what I found on rockauto.
hoothoot
11-28-19 05:01 AM
S160dre
08-11-16 06:36 AM
SICK350
ES - 5th Gen (2007-2012)
03-11-14 05:20 PM
ADENNARD
05-21-13 06:27 AM
Blaizze
10-03-08 12:37 AM
Quick Reply: B1S2 o2 sensor location and part number
