2008 headlight adjustment
Having trouble setting the aim of my 400h lights , I have the Hid /AFS . I can find the adjustment screw but I can find the adjustment screw from page 372 . It says I have to adjust both the same amount /turns . Any ideas what the screw in step two looks like ? I've been posting on another thread and people say just use one screw so is that correct ?
Thanks Eads
Thanks Eads
It will be a little wheel with teeth. You put a phillips head screw driver in the teeth to turn it. It toward the bottom of the back of the headlight close to the fender. You can see it if you look at the headlight from the side. It is tricky to find. Also..You will need a LONG screw driver to adjust it.
