Engine Warning Light P0500
My Check engine light comes on frequently. The corresponding code is P0500. Can anyone provide advice on how to replace the Speed Sensor?
Front speed sensor is actually pretty easy. Take off wheel. 10 mm bolt on inner part of steering knuckle where the axle runs through it. Take out bolt. Remove other bolt attached to wire up near strut. Remove from where it attaches to clip. Replace. You do have to reach under the week well plastic to find where it clips to the rest of the wire.
Alldatadiy.com has lots of information for a small fee and might have some instructions.
There are two 10mm bolts to remove along with the wire harness clip where it joins the rest of the wire that feeds to ABS/ECU.
