Headlight
Old 12-01-13, 05:49 PM
Leegs1
Leegs1's Avatar
Default Headlight
Own a 2006 lexus rx330. headlight bulb works occasionally. Replaced bulb and still works only occasionally. Is there a short somewhere? Any help would be appreciated.
Old 12-01-13, 05:59 PM
RX330inFL
RX330inFL's Avatar
Welcome to Club Lexus, Leegs1.
You do not mention which headlight system you have -- Halogen, HID or HID w/AFS?
There is a known condensation problem with the headlights on the 2nd Generation RX. Perhaps yours have gotten to the point when the water intrusion has caused corrosion and/or possibly ruined a ballast. If you use the search features for the forums here at CL you will find a number of existing threads on this topic. There is also a DIY sticky on the front page of this forum section which includes information on how to reseal your headlights. However, that would be after you have things working as they should.
Let us know what you have and perhaps others will chime in with more details of help.
Old 12-02-13, 12:51 PM
Leegs1
Leegs1's Avatar
Halogen. Dimmer headlight
Old 12-02-13, 01:59 PM
mandyfig
mandyfig's Avatar
Dimmer headlight means...? The low beam you mean?
Old 12-02-13, 04:42 PM
Leegs1
Leegs1's Avatar
Low beam is not working all the time.
Old 12-31-13, 08:07 PM
phungy
phungy's Avatar
http://www.lexusreimbursement.com/
I got mine replaced for free at Lexus because of the extended warranty and headlight condensation problem.
Old 01-02-14, 07:33 AM
rxpx40
rxpx40's Avatar
Leegs, you don't have a short somewhere. The definition of a 'short' is "A powered circuit shorted to the ground terminal." If you had a 'short' you would be blowing the fuse. What you have is called "An intermittent open circuit"
We can't troubleshoot your car from our computers. If you are asking if this is a common problem, I would hazard a guess ...not.
You also don't mention if it is one side or both your low beam lights. C'mon, man... throw us a bone here! We can't troubleshoot your car from our computers based off your two-word answers..
ozmanyyy
10-15-13 03:37 PM
BrightonB
01-06-13 07:47 AM
tdoom15
11-15-12 02:53 PM
prowler97
Hybrid Technology
09-27-12 11:43 AM
Todd
01-03-10 07:20 AM
Quick Reply: Headlight
