Cleaning rear caliper sliders
Old 07-29-13, 01:00 AM
aeroelasti
aeroelasti's Avatar
Default Cleaning rear caliper sliders
All,
The brake rotor/discs on my 2004 AWD show rusted surface. The visible side (i.e. the side where you can see in between the wheel spokes) are brown and not shiny but the other side (the side you can only see by putting your head below the car) is shiny.
Does this point to sticky slider pins? Or the RX use a different caliper system?
This sometime happens to my other car (VW Jetta) and I have cleaned and lubed the slider pins various times, which solved the problem. Is the RX set up similar? If so, is it just the case of removing 2 No. retaining nuts to access the slider pins?
Thanks in advance.
Old 07-29-13, 05:47 AM
RX330inFL
RX330inFL's Avatar
Pretty much. Have a look at the DIY from the sticky.
https://www.clublexus.com/forums/rx-...placement.html
Old 07-29-13, 06:06 PM
compdr59
compdr59's Avatar
I found that there's a rubber piece on one of the slides. Mine was binding and had to go to 2 dealers to find the parts. You may want to replace the complete boot kit if water is getting in.
Old 07-30-13, 04:19 AM
aeroelasti
aeroelasti's Avatar
Thanks all,
Will order a set of rubber booth first before I start stripping, I have a feeling that I might have to use heat gun to remove the slider pins.
I saw another DIY for Lexus RX 1999 which indicates that the rear slider pin is sleeved within the caliper holder, I hope the 2004 is not. Otherwise, it will be hard to get them out:
https://www.clublexus.com/forums/rx-...ust-boots.html
Can anyone confirm this is not the case?
Thanks
mikhett
RX - 3rd Gen (2010-2015)
07-19-17 08:05 AM
aeroelasti
06-21-12 02:36 AM
kkee
RX - 1st Gen (1999-2003)
08-08-10 09:09 PM
TXFM
03-17-07 11:45 AM
Quick Reply: Cleaning rear caliper sliders
