Thinking of buying a 09 rx350 93k miles?
the price we came to was 17000 for the car at the dealer, it is a 2009 with 93,000 miles on it.
I just wanted peoples takes, is this a good deal? car is from Maryland. is the mileage too high?
thanks
thanks
- Is the mileage too high? is there a maintenance record? sometimes the carfax report will have a list of maintenance record, if the car has been serviced by the Lexus dealer. I would not be worry too much with 93K, as long as it has been service regularly. A friend of mine owns a 2000 RX300 with 250K, and it is still running strong today.
Good luck,
That is a good price provided it was properly serviced. The Lexus service history for the vehicle is available at the link below. You will need the VIN to complete it:
https://secure.drivers.lexus.com/lexusdrivers/home
thanks for the input everyone. it has navigation, Bluetooth, backup camera etc.
This is the service record i pulled up at the website.
is it a go? I have a appointment on Monday since they are closed over the weekend.
looks like the car is from maryland.
Grodon, nope it isn't.
thanks,
Dealer Reported 12/03/2012 Lexus of Rockville 93478 0997415 WHOLESALE DETAIL
Dealer Reported 11/28/2012 Lexus of Rockville 93762 0996768 DIDN'T MSI
Dealer Reported 11/28/2012 Lexus of Rockville 93762 0996768 WHOLESALE
Dealer Reported 11/28/2012 Lexus of Rockville 93762 0996768 OTHERS R&R
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 TECH FOUND THE VEH IS ALWAYS ON DAY SAVING TIME
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 BERNIE KITT LOOKED AT VEH WANT TO SIT WITH THE CUSTOMER NEEDS HER PHONE TRIED WI
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 CUST IT SHOULD BE UNDER WARR. OUT OF WARR SPECAIL PARRT WARR 12MTH
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 7 POINT VEHICLE WALK AROUND RESULTS: BLEMISHES NOTED: 3 SCRATCHES, 1 OTHER TIRE
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 VEH ALSO NEED 4 TIRES AND ALIGNMENT TIRE PRESSURE LGHT IS ON RECOMMEND TIRES
Dealer Reported 02/24/2012 Lexus of Rockville 76072 0965790 CHANGE OIL AND FILTER : EXPRESS SERVICE , NO OTHER SERVICES PROVIDED.
Dealer Reported 02/20/2012 Lexus of Rockville 75603 0965016 CUSTOMER STATES: 7 POINT VEHICLE WALK AROUND RESULTS UNDER THE HOOD INSPECTION:
Dealer Reported 02/20/2012 Lexus of Rockville 75603 0965016 CUSTOMER STATES: CK THE BLUETOOTH EVERY TIME YOU CUT THE CAR THE CLOCK KEEPS GOI
Dealer Reported 02/20/2012 Lexus of Rockville 75603 0965016 PARTS SPECIAL ORDER.S/O NUMBER_________ FAULT CODES__________DESCRIPTION OF REPA
Dealer Reported 02/20/2012 Lexus of Rockville 75603 0965016 CUSTOMER STATES: GUEST CONTACT PHONE # Y/N E-MAIL Y/N SPECIAL INST. Y/N SPECIAL
Dealer Reported 02/20/2012 Lexus of Rockville 75603 0965016 CUSTOMER STATES: LEXUS MULTI-POINT INSPECTION
Dealer Reported 10/08/2010 Lexus of Rockville 47978 0909669 COMPLETED SERVICE.
Dealer Reported 10/08/2010 Lexus of Rockville 47978 0909669 NOTE: DON N. GAVE CUSTOMER $400.00 CREDIT, STILL HAD $156.44 REMAINING AFTER THI
Dealer Reported 10/08/2010 Lexus of Rockville 47978 0909669 BLEMISHES NOTED: 9 SCRATCHES
Dealer Reported 10/08/2010 Lexus of Rockville 47978 0909669 NOTE: ENGINE AIR FILTER AND A/C FITER ARE DIRTY $129, DIFFERENTIAL FLUIDS.$120
Dealer Reported 08/12/2009 Lexus of Rockville 19587 0865616 BLEMISHES NOTED: 3 SCRATCHES
Dealer Reported 08/12/2009 Lexus of Rockville 19587 0865616 REPAIRED
Dealer Reported 08/12/2009 Lexus of Rockville 19587 0865616 CUSTOMER STATES: 301-606-8611
Dealer Reported 08/12/2009 Lexus of Rockville 19587 0865616 R&R CONSOLE ASSEMBLY TO REPLACED BUTTON ASSEMBLY
Dealer Reported 07/30/2009 Lexus of Rockville 18774 0864470 BLEMISHES NOTED: 1 SCRATCH, 1 SCUFF
Dealer Reported 07/30/2009 Lexus of Rockville 18774 0864470 CUSTOMER STATES: MULTIPOINT INSPECTION
Dealer Reported 07/30/2009 Lexus of Rockville 18774 0864470 CHECK WINDOW WASHER FLUID - CHECK
Dealer Reported 07/30/2009 Lexus of Rockville 18774 0864470 5,000 MILE SERVICE
Dealer Reported 07/30/2009 Lexus of Rockville 18774 0864470 LEXUS PERSONALIZED SETTINGS
Dealer Reported 08/06/2008 Lexus of Rockville 10 0832115 PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
Dealer Reported 08/06/2008 Lexus of Rockville 10 0832115 STOCK CLEAN ON A NEW VEHICLE / PAINT PROTECTION
Dealer Reported 08/05/2008 Lexus of Rockville 11 0832569 STOCK CLEAN ON A NEW VEHICLE / PAINT PROTECTION
thanks,
There are some large gaps in service by Lexus, especially between 20k and 50k. Of course the lady that owned this vehicle could have had an independent shop do the maintenance. Many of us on the forum have service done by an independent shops or the local Toyota dealership. It appears that you are purchasing this vehicle from the Lexus dealership since they are doing the wholesale. The fact that this RX also has the navigation is a real plus. It's your call, but you are getting this for a good price.
its a non lexus dealer.
Stevebarth
GX - 1st Gen (2004-2009)
10-13-17 10:00 AM
kevin9812
RX - 1st Gen (1999-2003)
05-14-15 06:45 AM
