rear windows don't work help
Just bought my 2004 rx and everything works but the rear windows.Is there a fuse that could be bad.Both of the windows won't go up or down.Thanks Jimbo
If none of the switches work to open the rear windows, you can check fuses #35 and #36 (which should be the first few) in the driver side footwell as shown in the Owner's Manual:
http://drivers.lexus.com/t3Portal/do...004rx33/64.pdf
widow problems
I tried the switches in the back door and they both work. I then tried using the front door switches again and the rear passenger door works but the rear side on the drivers side still won't work with the front door switch. Very strange.Why would the one rear door window and the other one won't
Thanks Jimbo
Thanks Jimbo
Thanks Jimbo
Thanks Jimbo
http://drivers.lexus.com/t3Portal/do...004rx33/12.pdf
dcdyd
10-28-17 02:28 PM
