noise from right rear
Old 07-22-12, 10:26 AM
rxovermdx
rxovermdx's Avatar
Default noise from right rear
Hey guys, I just noticed that my RX is making "sha sha sha" noise (proportional to the car speed) from the right side back tire/rotor when I am coasting. The nosie doesn't change when I use the brake. I haven't driven the car fro about 6 months, and today was first time driving it. in a while. It is a 2008 RX 350 FWD with about 23,000 miles. Before I take it to the shop, I would appreciate any thoughts. DO I need any maintenace lubricant on any axles ?rusted rotor. I am hoping it is not the bearing or drive shaft.
Old 07-22-12, 11:12 AM
rsr91128
rsr91128's Avatar
Was the parking brake set while it was parked?
My pickup will do that if I leave the brake set for long periods.
Could just be rust on the parking brake drum inside the rotor, you could try slowing pushing the parking brake down while driving slowly on a side road to see if the noise goes away. Keep in mind you'll have to stop completely to turn the parking brake off so do the test away from traffic.
Old 07-22-12, 12:27 PM
rxovermdx
rxovermdx's Avatar
No, I didn't have the parking brake on, but my car was parked at a slight decline (10-15 degrees). Any other thoughts?
Old 07-22-12, 12:31 PM
Rainbird
Rainbird's Avatar
It might be a wheel Wheel Bearing. I would have Lexus check it out. You would be covered under the drive train warranty.
Old 07-22-12, 03:54 PM
ELITech
ELITech's Avatar
while it could be wheel bearing, I would think that it sitting for six months caused a lot of rust build-up, particularly on the inside of the rotor that you cannot see. Wheel bearing would create more of a roaring noise...
Old 07-23-12, 06:34 AM
thomas1
thomas1's Avatar
Actually that sound was how mine sounded, turned out being a front left wheel bearing.
veez81
09-05-17 11:52 PM
songlou
02-21-16 09:57 AM
garfull
RX - 3rd Gen (2010-2015)
08-13-10 06:09 PM
lexoticus
Suspension and Brakes
07-14-06 01:58 AM
Quick Reply: noise from right rear
