Oil change question
Old 04-10-12, 12:09 PM
Cb4h
Cb4h's Avatar
Default Oil change question
Quick question is the oil filter wrench on Sewell's website for the RX350 the same as I would need for a 330? Thanks
I appreciate it
Ty
Old 04-10-12, 12:46 PM
rcy
rcy's Avatar
Off the top of my head, I'd say no because the RX350 uses a cartridge type oil filter whereas the RX330 uses the screw on type filter. However, not having an RX350 to check, I'm not sure what the oil filter cap looks like - maybe it's the same shape as the top of a screw on type filter..
Old 04-10-12, 02:05 PM
Cb4h
Cb4h's Avatar
wil i even need an oil wrench or just twist it off?
Old 04-10-12, 02:46 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
if your hand is strong enough.....
just get the generic oil filter wrench will do the job....you do not need the one from Sewell.....
Old 04-10-12, 03:26 PM
Rainbird
Rainbird's Avatar
Here is a DIY oil change procedure with PICTURES. The GS350 and RX350 are done the same way. The old spin off type oil filter went away with the 2007 model year.
https://www.clublexus.com/forums/gs-...-pictures.html
Old 04-15-12, 05:05 PM
Poppi
Poppi's Avatar
Actually the old spin-off type oil filter went away with the 2006 RX330 model yeear. Cartridge filter new starting with 2007 RX350.
Old 06-13-23, 11:57 AM
PJRNJ
2nd gear
PJRNJ's Avatar
What Type motor oil 2006 rx330
new here
Old 06-13-23, 12:32 PM
MattRX
MattRX's Avatar
5W-30 you need about 4.7 L with a new filter (D1 is the size from Toyota/Lexus). I just pour the whole jug in and it's at the max line
mandyfig (06-16-23)
azncapcom
06-15-20 06:51 AM
GConcept99
Maintenance
07-23-12 03:15 AM
OutlawTita
CT 200h Model (2011-2017)
12-18-11 04:46 AM
JerzeeB
05-26-11 02:03 PM
jimboco10@
08-08-08 06:18 AM
Quick Reply: Oil change question
