RX air suspension swap out?
air suspension problems
i also am experiencing the same problem
did you use just regular struts/
I would also love to get a copy of the diagram you spoke of , if you dont mind
Hey guys I am checking back in after doing the swap. I got a set from online junkyard for $550 shipped. I swapped them all out in my garage in about three hours. I got the car aligned and it now rides like a dream again. I have not yet decided what to do with the air system components. I will likely clamp the four lines at the ends or remove the compressor itself. No issues so far with any of the other car systems. Light is on in the dash only annoyance.
Does anyone know where the compressor unit is and how to access it for removal? That is whAt is bad so I will remove it and never look back. Also I now have four used airbag struts for sale with 83K on them! Let me know if interested they are all in good shape. My email is markbmx@msn.com
Did you have to buy anything else, like strut mounts or special tools? Thanks
If it has a separate fuse, the light that blinks off for the air compresssor, I would just pull the fuse.
I've done the coil over conversion from air struts. I used a kit from strutmasters...easy install, lifetime warranty and good ride.
The warning light on the dashboard is easy to disable, although it doesn't have a separate fuse. Simply pull back the instrument bezel...its only held on by plastic clips. Take out the four screws holding the instrument cluster in place and turn it over to gain access to the two wire connectors on the back. Cut and tape the white wire on pin 9 on the small connector and the warning light is permanently disabled.
Cheers!
Cheers!
we are experiencing issues with the right side of the car being way lower then the rest of the car. We have disconnected the battery once to have it all level out again for about 2 weeks. Just did the same thing again so did the battery trick to only have it last this time about 24 hours. Now we are needing to know what should be replaced, or looked at as we are thinking it might be the compressor height control assembly going bad, but no idea where to locate it. It is a 2004 RX330 with about 190,000 miles on it and I am not sure the time, money is worth the age and mileage of the car. Any help is very much appreciated.
Cheers!
Cheers!
Margate330 (11-13-22)
The height sensor on the problematic side would possibly not working properly. I had to rebuild the mechanical joint was totally stuck and corroded and not moving the sensor link accordingly to the vehicle height. I finished cleaning the corrosion with WD-40, and re-working joint ball to take out the corrosion, and coating broken rubber seal with poliuretan glue. Make sure to put grease to the joint prior totally sealing it with the glue. Glue is stiffer than original rubber boot, but strong and flex enough to to do the work even at -30C. I checked all four sensor's joints and had to repeat the procedure on everyone as they have being close to failing as well. No problems on air sensors science the repair happened, and it's more than a year for now.
Another new member!
Welcome to Club Lexus and contributing on your first post ~!
Eddyson (11-14-22)
camberSC
SC- 1st Gen (1992-2000)
63
02-07-09 02:50 AM
04, air, club, compressor, conversion, converting, lexus, problems, remoce, rx, rx330, standard, struts, suspension, swap
