Update:330
Old 12-13-11, 08:52 AM
lexuskyom
lexuskyom's Avatar
Default Update:my ride
So it seem that there isn't anything that can be done with the rx330 engine noise, specifically the ticking noise. I was told it's normal for the rx. I find the noise is annoying. At idling, the ticking is loud and when it's cold outside. If i knew about this type of imperfection with lexus, i probably wouldn't buy a lexus at all. My rx is a lexus certified pre-owned. Does anyone else have this too or it's just the luck of the draw?
I wonder if the newer model rx have this engine annoying noise too ...
Old 12-13-11, 10:04 AM
Brad39
Brad39's Avatar
My 2004 RX330 makes the same sound with only 60K miles on it
Old 12-13-11, 10:28 AM
MrBruin09
MrBruin09's Avatar
turn up the volume on your radio, it should drone out the noise.
Old 12-13-11, 10:41 AM
infinirx
infinirx's Avatar
I have no idea what this noise is that your mentioning. My 330 is at almost 120K.
Old 12-13-11, 11:36 AM
lexus114
lexus114's Avatar
I have no noise either, in fact @ an idle I can barely even tell its running.
Old 12-13-11, 01:14 PM
Carver
Carver's Avatar
Wasn't the ticking noise on a TSB? Sticky injectors?
Old 12-13-11, 01:48 PM
Rainbird
Rainbird's Avatar
Carver is correct. Check out this CL forum posting:
https://www.clublexus.com/forums/rx-...ing-noise.html
Old 12-13-11, 05:00 PM
Nick318
Nick318's Avatar
my Rx has zero idling noise after 5+ years of driving it. I think yours is an isolated case. Remember when buying a used car, don't expect it to be all perfect.
Old 12-13-11, 05:25 PM
hypervish
hypervish's Avatar
My 11 year old RX is quiet at idle, and you can't even tell it's running. I have to look down at the tach sometimes to see if it's still running. LOL
Old 12-13-11, 06:13 PM
Sandhopper
Sandhopper's Avatar
Mine is quiet as a church mouse at 125K... how many miles do you have on your 330?
Old 12-14-11, 12:14 AM
Emilaman
Emilaman's Avatar
Engine noise is okay, but not the ticking. Find good mechanic and ask him to check everything. I had ticking noise on my previous dodge caliber, problem was alternator and couple pulleys. On my RX330 with 225000 miles on it i can hear only engine working noise but nothing ticking or clicking
Old 12-14-11, 05:29 AM
jfelbab
jfelbab's Avatar
Not a peep out of my 04 RX330 at idle. This is not, as your dealer implied, "normal". Their tech is just not skilled enough to find it or they don't want to address the problem. Take it to another dealer and see what they say.
Old 12-14-11, 09:24 AM
tomit
tomit's Avatar
It's possible the ticking noise is caused by carbon buildup in the combustion chambers. Try a can of BG 44K. Can't hurt and may help.
Tom
Old 12-14-11, 03:46 PM
grouch
grouch's Avatar
Mines a Canadian built and it TICKS. It's too far out of warranty for the TSB, so I'll live with it.
Old 12-14-11, 04:26 PM
Emilaman
Emilaman's Avatar
Did u take it to mechanic to see what is the problem?
Quick Reply: Update:330
