Is this an oil leak?
Old 07-14-11, 02:36 PM
wootw00t
wootw00t's Avatar
Default Is this an oil leak?
2009 RX350 parks here in this pic. I should've took a close up picture but it does look oily and dark black. Is this where it will drop down on the ground on driver's side if it's an oil leak?
Old 07-14-11, 04:33 PM
RX330inFL
RX330inFL's Avatar
Did you have an oil change recent? Could just be a drip from the draining process getting on the under carriage on from the fill process.
Also, are you sure it is oil? It is ok to touch with your finger to see if it is brown/black or red.
Old 07-15-11, 04:34 AM
DixieLex
DixieLex's Avatar
Default Park it at another spot
and leave it after running a while (but after you check the oil and other fluid levels) and see if its leaking.
Looks like oil
Old 07-15-11, 06:57 AM
mandyfig
mandyfig's Avatar
Def oil. But a big splash. Not the drip drip small.
Old 07-15-11, 07:51 AM
Rainbird
Rainbird's Avatar
I get a one time drip like that after the dealer does an oil and filter change. Sloppy refill I guess.
Old 07-15-11, 10:13 AM
mandyfig
mandyfig's Avatar
Bet you it is the above. Sloppy, right word. Just hope they torqued that bolt the right way.
Old 07-15-11, 10:33 AM
Nick318
Nick318's Avatar
Oil leakage should be under the passenger's side for the RX if there's one. Overfill of oil is seen on the center.
Old 07-15-11, 11:22 AM
mandyfig
mandyfig's Avatar
Have a valid point.
Ryan300
RX - 1st Gen (1999-2003)
19
08-01-22 11:15 AM
bdpride04
10-31-17 12:59 PM
jagdeep510
05-02-15 05:11 PM
bguild
GS - 1st Gen (1993-1997)
14
07-19-07 06:29 AM
Quick Reply: Is this an oil leak?
