Lost Wheel lock, what to do?
Old 03-19-11, 05:23 AM
  #31
txt
txt's Avatar
Originally Posted by txt
Did anyone buy the regular (non-locking) wheel nuts ?
Do you have the part number of the non-locking nuts ?
Here is what I saw on line at Autozone.com. I've not bought them yet.
Dorman Wheel Nut/Wheel Nut
For your 2009 Lexus Truck RX350 2WD 3.5L SFI DOHC 6cyl
Price:$1.99
Part Number: 611-211.1
Alternate Part Number: 9905
Old 03-21-11, 05:24 AM
  #32
quantfutur
quantfutur's Avatar
Had a flat at Logan on my previous car ('99 RX 300). When they tried to change flat, found the wheel nut was distorted and thus the key wouldn't work, so had to be towed. A very long nite..... Changed to keyless wheel nuts and never looked back.
I figured the concept is enough of a deterrent from the rare tire theft, anyway. Are hoods going to be searching for that RX with the keyless to steal the tires?
Old 03-21-11, 06:43 AM
  #33
Sunset
Sunset's Avatar
Advanced Auto Parts in Eastern Pennsylvania is where I got mine.
Old 03-21-11, 07:55 AM
  #34
Carver
Carver's Avatar
Originally Posted by quantfutur
... Are hoods going to be searching for that RX with the keyless to steal the tires?
Well, I'm paranoid enough about my hot new chromies to keep a lock on there.
Old 03-21-11, 02:43 PM
  #35
quantfutur
quantfutur's Avatar
I agree, Carver -- they might want to steal your chrome ones!
Old 03-28-11, 09:33 AM
  #36
mandyfig
mandyfig's Avatar
Originally Posted by Nick318
Call 1-800-444-5847 and ask them to direct your call to Nancy
Her email: cs3@mcgard.com
Thanks a lot bud.
Old 03-28-11, 09:39 AM
  #37
mandyfig
mandyfig's Avatar
I just sent my pics, here's to a good and painless (less $) resolution!
Old 03-28-11, 10:02 AM
  #38
mandyfig
mandyfig's Avatar
Wow that was pretty quick from Nancy. I actually have a set with 2 lug nuts missing, sent the pics and my cost will be $10.49 for each of the lug nuts. I am ordering it now.
I will have locks for the SC.
The RX will have no locks after I dump the 2 which are still installed. Will get Lexus to unscrew it and replace with regular lug nut when they do the recall on the floor mats.
Thanks for the tip.
Old 08-12-11, 04:57 PM
  #39
svanvooren
svanvooren's Avatar
Default So how did the lug nut issue work out?
Thanks for the tip.
I have purchased a used '02 LS with no key. Trying to figure out what to do.
Old 08-12-11, 05:26 PM
  #40
RX330inFL
RX330inFL's Avatar
If you feel OK about going sans locks, I would go to the dealer and have them remove the locks on each wheel and replace them with a standard wheel lug nut. They have universal tools for such situations. Not sure if a Toyota shop can do the same or if your local tire shop can help remove these.
You can have them "cut" off. However, that requires you to then replace the wheel lug stud as well as getting new lug nuts installed.
If you want a set of locks you might be best served by just buying a new set from the dealer, Sewell, or from your auto parts store to have installed once you get the current ones off. Check above posts for the AutoZone part number. Should be similar for your LS.
Old 08-12-11, 06:21 PM
  #41
mandyfig
mandyfig's Avatar
A Lexus mechanic brought home one of the 10 master keys for the McGard. My locks have been removed. No more locks. Was not able to update to let you guys know.
Old 08-14-11, 08:37 AM
  #42
svanvooren
svanvooren's Avatar
Default Thanks.
I could care less about the locks. They are the standard wheels for an '02 with some "character" on them.
Old 08-14-11, 09:31 AM
  #43
jgr7
jgr7's Avatar
My Toyota dealer also has the set of keys they use when no key is present, I saw them do it to mine when they said they couldn't find my key. My key was right where it has always been.
Jeff
Old 08-15-11, 05:59 AM
  #44
mandyfig
mandyfig's Avatar
They say there are 10 master keys. 1 look at the lock, they know what master to use.
Old 08-15-11, 06:00 AM
  #45
mandyfig
mandyfig's Avatar
Of course these are well guarded, the lock keys are.
Quick Reply: Lost Wheel lock, what to do?
