RX 350 headlamp moisture
Old 01-10-11, 07:24 AM
ajgregory
ajgregory's Avatar
Default RX 350 headlamp moisture
Hi,
Seems headlamp moisture has been an ongoing problem in the RX series. I have this issue in the left headlight on a '07 RX 350 which is unfortunately out of warranty as it has 60k+ miles on it. Has anyone been successful in getting this fixed by Lexus with the vehicle out of warranty?
Thanks in advance!
Old 01-10-11, 02:03 PM
mandyfig
mandyfig's Avatar
Check on my DIY post for the leak repair on the headlamp condensation. So sad that the 07 still had issues. Thought it was killed after 05.
Old 01-13-11, 07:30 PM
ajgregory
ajgregory's Avatar
Default Drawing a blank!
Hi Mandy,
I was struggling initially (hard to believe I could miss the 'search' menu for so long) but just now found your previous post - awesomely detailed - thank you!
Best - A
Last edited by ajgregory; 01-13-11 at 07:43 PM. Reason: don't wanna talk about it!
Old 01-13-11, 07:41 PM
mandyfig
mandyfig's Avatar
Search for headlamp condensation...
Old 01-13-11, 07:43 PM
mandyfig
mandyfig's Avatar
Search is your friend:
Take a look here:
https://www.clublexus.com/forums/rx-...densation.html
Old 01-13-11, 07:47 PM
mandyfig
mandyfig's Avatar
Before you take the headlamp apart I suggest that you try to seal the top of the headlamp, that's the source of the leak in my case. It will save you tons of time and aggravation.
Here:
https://www.clublexus.com/forums/rx-...epair-tip.html
Old 01-13-11, 08:07 PM
mandyfig
mandyfig's Avatar
Let us know how you make out. Good luck.
Old 01-21-11, 06:25 PM
ticdoc
ticdoc's Avatar
There is a class action lawsuit regarding the defective Lexus Headlamps and Moisture. Check it out!
http://www.topclassactions.com/lawsu...t-class-action
Old 01-21-11, 06:43 PM
Rainbird
Rainbird's Avatar
Thanks to "ticdoc" for this information. I don't have this headlight moisture problem, but fellow RX friends mine do. I have bookmarked this. Toyota needs to acknowledge this problem and fix it.
Old 01-21-11, 06:47 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Somebody should do their homework before posting pictures on a website. They're showing a 2010+ 450h. Duh! I had condensation in both headlights of my '04. The dealer replaced them under warranty without batting an eye. Wish it was easier for everyone else.
Old 01-23-11, 02:17 PM
mandyfig
mandyfig's Avatar
I was declined repair on my condensation problem, just 1.5 months after my warranty expired. Sure sucked. I might sign my name on that petition.
Old 01-23-11, 06:35 PM
iamkhanz
iamkhanz's Avatar
one of the guys who had an audi with same problem told me to put a small drop of antifreeze somehow into your assembly and it should get rid of the water..had this on my toyota and it worked..
Old 01-24-11, 08:02 AM
mandyfig
mandyfig's Avatar
Anti-freeze, wow that's new. Is that supposed to melt the seal and re-seal it?
Old 01-25-11, 10:30 AM
ajgregory
ajgregory's Avatar
After perusing the class action filing I'd recommend that anyone with a 2004-2007 RX monitor this lawsuit. It is possible that even if Lexus has replaced your headlight(s) for free the issue may recur. Additionally, anyone who's done a DIY fix may still have water damage such as rusting of the ballast.
The filing alleges that the fix for this issue may only delay the recurrence of the problem. With replacement (parts & labor) running in the region of $2,000 per headlight it would be nice if Lexus would stand behind it's product!
Old 01-25-11, 01:58 PM
iamkhanz
iamkhanz's Avatar
no just suppose to get rid of the moisture
tomsawyer
RX - 3rd Gen (2010-2015)
25
03-19-23 07:10 AM
irfanm67
09-16-19 06:33 PM
fre3way3
02-09-16 04:22 PM
jednav
04-03-07 11:41 PM
Quick Reply: RX 350 headlamp moisture
