04 RX330 - Power liftgate issue
Old 11-16-10, 12:06 PM
RX330inMD
RX330inMD's Avatar
Default 04 RX330 - Power liftgate issue
I have a 04 RX330 AWD and I noticed yesterday when I opened the rear door, it didn't stay open when it reached the top. As soon as the rear door reach the top position, it came back down and closed the door. First, I thought I pressed the button to close but when I tried a few more times, it was keep happening.
Can someone please help me what I need to do?
Thank you.
Old 11-16-10, 01:03 PM
mowmow
mowmow's Avatar
Do you have any object obstructing the door mechanism ? Double check that if not call dealer up and ask them to first try to reset the rear lift gate if all else fail, diagnostic.
Old 11-16-10, 02:32 PM
jfelbab
jfelbab's Avatar
You can try manually opening and closing the door which resets the system. You might also lightly lube the strut braces to reduce any friction. My 04 was getting a bit slow and noisy until I lubed the strut shafts with a little silicone.
RX330inFL
RX330inFL's Avatar
Also try lubrication of the lifts. Silicone spray not lithium grease. May be sticking a bit and the friction may be causing the issue.
Old 11-16-10, 09:23 PM
RX330inMD
RX330inMD's Avatar
Thank you everyone who replied. I will try those recommendation first before I call the dealer.
Old 11-17-10, 07:50 AM
mandyfig
mandyfig's Avatar
Lubing the struts was on my TD list, good reminder, must do mine.
Old 11-21-10, 08:10 AM
vg1134
vg1134's Avatar
as mentioned lube or it may be that the lift gate need resetting. Its in the owner manual some where.
Old 12-16-12, 08:02 AM
jamieZ
jamieZ's Avatar
Unfortunally nobody really understands how the rear door works including myself.I really don't think Lexus techs know much about it either. When under warrenty they just throw new parts in until something works. When the vehicle is NOT under warrenty that option gets costly quick. I guess we live with it. I have the same issues, so do a lot of other customers and there is no real solutions that i can see. Jamie
Old 12-02-14, 09:02 PM
Trex2005
Trex2005's Avatar
Replace the rear hatch support struts. It's simple. I did it on my own and it takes 5 mins to pop the clip off and insert a new one. Got them on Amazon for less than $50 for two. Struts only last about 5 years before they get weak enough to start causing ssues
Old 12-05-14, 04:56 PM
mandyfig
mandyfig's Avatar
Try the lubing...but when it is cold the struts start being slow...
sbklf
05-12-23 04:26 PM
javohio
05-12-23 09:54 AM
ADAM P
04-01-15 07:17 AM
jsperrella
12-16-12 08:07 AM
toppower
11-29-07 09:02 PM
Quick Reply: 04 RX330 - Power liftgate issue
