AC not blowing cold...HELP! I live in HOT Texas!
No, I don't play soccer!
Well, again, this is not for your standard DIYer. As someone whose father teaches freon recovery to engineers and a brother who is an HVAC chief engineer, I would not suggest trying to work with this stuff. Read the safety sections in your wikipedia links above. A/C techs are trained to follow EPA-mandated handling procedures and have the proper equipment.
Spending the money up front to diagnose the problem may save hundreds down the road when the compressor fails which happened on my RX300. The extended warranty saved me the repair cost of $600-700, and that was for a remanufactured compressor.
Spending the money up front to diagnose the problem may save hundreds down the road when the compressor fails which happened on my RX300. The extended warranty saved me the repair cost of $600-700, and that was for a re manufactured compressor.
Fine, do what you want. Have that cheap can of freon explode in your face when that gauge or valve you think is adequate fails.
Degree or not, all auto techs have to be certified to work A/C systems.
http://www.epa.gov/ozone/title6/609/.../609certs.html
Yes, it's technical but a hell of a lot more than you think. Go ahead, take the test to find out how much you think you know.
BTW, I'm always troubleshooting my self for any problem even with home appliances, by reading on internet, asking people or trusted techs, before I will take a car or call service for repair, if I would not be able do it myself. A life taught me never trust service people in America, a lot them just scammed money from you.
Yet, I was fixing airplanes for major airline for 6 years, so believe me I went from tech to engineer myself. I have seen a lot people don't have any skills even to replaced a tire. And remember it's airline business, just imagine in the auto business. I would never gave my car for service or repair just to the random guy, even it's a dealer. Like quick lube places. I did one time by my trusty stupidity, so never replaced filter on my BMW. I found it after 5,000 miles. The filter was completely looked like a sponge.
So it's your car and your money and it's fine with me.
http://shop.advanceautoparts.com/web...T|GRP2004A____
and this
Freon is a just trade name or simple refrigerant, that's all. That was my point. How is hard to understand? It doesn't matter how you called it.
Well brakes replacing is also can be left for professionals.
So what is forum for and DIY? Some can do the only tires servicing some can replace an engine in the garage. It's all depended of your craftsman skills and equipment for it.
I've suggested a simple DIY, that a "cave man " can do.
http://www.amazon.com/gp/product/B00...B87NYD0G5RV230
Most shops will diagnos your A/C for under 100 bucks, you are better off taking you walmart money and getting it properly diagnosed.
I had similar problem happen to me, it turns out to be a punctured AC condenser and not it was not covered under warranty and it costs $1500 to get it fixed at stealership so check your AC condenser also.
My other car had a A/C leak on it. I had to pump 1 freon can every year. The other year I brought a refrigerant can with sealer and it completely sealed and fixed the leak. This year the a/c still running without any need of new freon can. I fixed the a/c for $25. There is nothing wrong with buying a freon can from the store and pump it in. Some can come with the connector also. No need for other tool to pump the freon to the car.
its still not freon on your car, its R134a.
second, phylfy, you mentioned releasing some pressure till your car worked, guess what, engineer, thats illegal, r134a and freon are both ozone depleting, which is one of many reasons you need certification to work on an A/C system.
third, if you went to the right place the first time you probably would have had it fixed correctly. people harp on the dealer, but in most cases, they know where to look the quickest.
Yup, the fine for illegal discharge can be in the neighborhood of $10K. The EPA takes this offense very seriously.
"HFC–134a in particular has claimed a large share of the market for non-ozone-depleting substitutes in these applications."
So you are guys working for Lexus dealer, I meant stealership.
And I said before Freon is trade mark only.
Yeah, let us know!
I'd like to know as well. I put a little over one can in my wifes car and it was blowing ICE cold. It has only been a few days and I can tell that it already isn't as cold as it was so I definately have a pretty good leak somewhere. I put some 134a with dye in it so I will get out the blacklight and see where it is leaking. I read a post about the condensor having a recall issue and leaking prematurely so I will check that thoroughly. Our RX has 95k miles on it so no warranty will apply.
