Toner-cover and bar noise
Old 07-27-10, 05:27 AM
rxovermdx
rxovermdx's Avatar
Default Toner-cover and bar noise
I know sedans are much quiter with less interior noise than SUV since it has a trunk, but there is too much nosie coming from the tonneau cargo-cover and the bar area, this is without any groceries in the back. I took cover and the bar out and what a difference..so quiet!! But I rather not have to do that..any ideas or suggestions?
08' RX350 Navi
Last edited by rxovermdx; 07-27-10 at 10:36 AM. Reason: are you happy now RX330inFK
Old 07-27-10, 06:15 AM
veleno
veleno's Avatar
I'm a little confused, what area are you referring to?
Old 07-27-10, 06:58 AM
ycl1688
ycl1688's Avatar
This about luggage cover at the rear, I have been disgusted with the dealer they wanted $110 just for putting in a piece of plastic part on each side of the pillar of the rear door, just to get rid of the noise. will list the part # when I have time.
Old 07-27-10, 07:10 AM
draco
draco's Avatar
I assume you mean the rear cover that you slide to hide anything that you might have in the boot (trunk)? What do you mean by a piece of plastic on each side of the pillar of the rear door?
I have an 03 RX330 (04 US). Maybe a picture of what you are referring to?
Old 07-27-10, 07:51 AM
ycl1688
ycl1688's Avatar
draco,
I know a picture worth a thousand words, what I am referring is the cover ends that hung at the rear door pillar (the grove) needs the parts 67754-48050-B0 to silence the rattle noise. Right now what I am doing is to take the cover off and let the plastic parts at the grove point to 9:15 position that get rid of the noise.
Old 07-27-10, 10:12 AM
RX330inFL
RX330inFL's Avatar
He means Tonneau Cover
Old 07-27-10, 03:41 PM
draco
draco's Avatar
I suspected tonneau cover. Not sure what these groove things are though. I don't remember seeing anything in the back that you could point to a 9.15 clock position. YCL688 can you provide a picture of what you are referring to?
Old 07-27-10, 04:39 PM
cmichael
cmichael's Avatar
The part, based on the number you gave, is listed as SPACER, BACK DOOR TRIM.
Perhaps someone here will know what that refers to.
Old 07-28-10, 05:21 AM
ycl1688
ycl1688's Avatar
to make matter clearer here is what I am referring to when you unfold the cover one end, near the rear door frame will be latched to hold the cover. There are latches in the grove on both sides. Since I am not using the cover the latches should be at 9:15 position so the rattle noise will not bother you. as for the parts i am referring to it is worth putting in I do not know.
Old 07-28-10, 08:11 AM
draco
draco's Avatar
a picture detailing exactly what you are referring to would make this thread a 100 times better. I figure you are talking about the latches that hold the tonneau cover in place or allows it to automatically retract when the rear door is opened. I suspect you mean the tonneau-cover "rails" that are mounted either side of the car that the tonneau cover slides forward and back in. Still have no idea about this 9.15 position you are talking about (nothing in this area suggests a 9.15 position for me) and the part that you are trying to get. Picture will help alot.
Old 07-28-10, 08:17 AM
Rainbird
Rainbird's Avatar
I took my 2007 RX350 to the dealer for the VVT-I oil hose replacement. I also mentioned the annoying rattle in the rear hatch area. They were aware of the rattle problem and performed the TSIB NV5016 - Tonneau Cover Latch Rattle repair. The following parts were replaced:
1 67754-48050-B0 Spacer, Back Door TR
1 67754-48060-B0 Spacer, Back door TR
This repair solved the rear cargo rattle for me.
Old 07-29-10, 06:59 PM
rxovermdx
rxovermdx's Avatar
Thanks for the info Rainbird, what did they charge you for your tonneau repair, under warranty??
Old 07-29-10, 08:59 PM
Rainbird
Rainbird's Avatar
The repair was done under the Lexus 48 month warranty.
Old 07-29-10, 10:08 PM
RXSF
RXSF's Avatar
the first thing I did with both my RX300 and RX330 was remove the "toner" cover, haha
igzy
ES - 5th Gen (2007-2012)
08-30-18 12:20 PM
Fleainat
RX - 3rd Gen (2010-2015)
14
06-21-13 07:30 AM
forumnoob
04-11-10 06:53 PM
pleventi
09-19-09 10:07 PM
sakaike
09-09-07 03:55 PM
Quick Reply: Toner-cover and bar noise
