tire pressure warning light
Old 03-26-10, 05:44 PM
sonny1948
sonny1948's Avatar
Default tire pressure warning light
does anyone know how to disable the low tire pressure warning light on a rx350? TIA
Old 03-26-10, 07:48 PM
ilvmyrx350
ilvmyrx350's Avatar
Make sure all your tires have enough psi, and that includes the spare tire in the back of ur car. I got the same problem recently.
Old 03-26-10, 08:06 PM
Rainbird
Rainbird's Avatar
Almost every time it was the spare tire low on air. I finally got smart and filled the spare to 40-psi. Problem solved.
Old 03-28-10, 01:14 PM
xfirechief
xfirechief's Avatar
Spare was our problem too. Dealer said when weather changed to cold they were getting over 15 vehicles a day where they just filled the spare a little.
Old 03-31-10, 05:37 PM
sonny1948
sonny1948's Avatar
I have a system failure so I would like to disable it if someone knows how. I'm beginning to think it can't be done. TIA
Old 03-31-10, 08:49 PM
Rainbird
Rainbird's Avatar
Did you reset the TPMS system? That will usually fix the problem. The procedure is in the Lexus RX Manual.
Old 04-01-10, 05:17 AM
sonny1948
sonny1948's Avatar
Yeap...I tried that...but it want reset with a system failure.
Old 04-07-10, 06:14 AM
ilvmyrx350
ilvmyrx350's Avatar
I thought I had this problem fixed after I put more air into the spare, but I still have the warning light on. Any suggestions?
Old 04-07-10, 07:56 AM
Rainbird
Rainbird's Avatar
As above, reset the TPMS system.
Old 04-07-10, 02:39 PM
ilvmyrx350
ilvmyrx350's Avatar
Finally got rid of the annoying warning light by reseting TPMS. Thanks all!
roadbike56
01-15-16 01:42 PM
bonnier
RX - 3rd Gen (2010-2015)
13
01-18-13 07:05 PM
Piece350
02-01-12 06:53 AM
garsarno
ES - 5th Gen (2007-2012)
09-14-10 08:28 AM
dlap
03-07-10 06:24 AM
Quick Reply: tire pressure warning light
