Crack in the Dashboard!!!
Old 03-10-10, 05:11 PM
LS460CUSCO
LS460CUSCO's Avatar
Default Crack in the Dashboard!!!
I have a crack in my dashboard, my RX is really lightly used, and the man at the Dealer said that he could fix it, but it will be very obvious, any recommendations, because I really don't want to change the whole dashboard.
Attached Thumbnails Crack in the Dashboard!!!-img00025-20100310-2005.jpg   Crack in the Dashboard!!!-img00027-20100310-2005.jpg
Old 03-10-10, 05:16 PM
redrocks
redrocks's Avatar
FL?? I guess your RX wasn't garaged vice out in the sun all the time?
Old 03-10-10, 07:05 PM
kiwi
kiwi's Avatar
find someone else to repair it, there are some people out there who can hide it well.
Old 03-10-10, 09:55 PM
Rainbird
Rainbird's Avatar
After you get this repaired, treat the dashboard with "Aerospace Protectant 303". It has SPF-40 and is the best UV protectant you can buy. The 303 will give it a matte finish and protect this from happening again.
Old 03-10-10, 11:20 PM
salimshah
salimshah's Avatar
Seems like a stress break and not UV issue. Look for leather mender ... specially a shop who the Lexus dealer use. {they have matching dye-paint). I would not look for the cheapest place, as a botched repair can make things look worse.
Salim
Old 03-11-10, 06:29 AM
mandyfig
mandyfig's Avatar
Stress crack. Due to impact. There are places who can repair them. Better than what it is anyway. Good luck finding a guy. Post after repair.
Old 03-11-10, 06:30 AM
mandyfig
mandyfig's Avatar
I use AS303 on all my cars, in and out! Best UV protection! Not that expensive, too. I have a gallon of it. Fleabay has them by the bulk.
Old 03-11-10, 11:36 AM
salimshah
salimshah's Avatar
Few years back, the state inspection sticker is now attached to the inside of the windscreen. Well a careless inspector used his blade to scrape off the old sticker without putting a board on the dash ... guess what the scraper slipped and went right through the dash, leaving a 2.5" long gash. I went to "Leather Menders" (here in Austin) and they did a wonderful job. If you dont look for it, you cant even tell. The only tell tale signs are due to a straight cut/repair.
A good repair would need to bring the piece in level before the path is done.
Salim
Old 03-01-11, 05:50 AM
anton4oo
anton4oo's Avatar
Hi LS460CUSCO. i have RX 330 2005. I got the same crack on the same spot. My car is garaged most of the time. it seems strange because it appeared just like this. It,s strange. i have not done nothing as of now.
Old 03-01-11, 08:58 AM
mandyfig
mandyfig's Avatar
Welcome to CL. Post a pic of your crack and we can compare.
Old 03-04-11, 11:43 AM
rx400h1976
rx400h1976's Avatar
Are there any recommendations for removing light scratches from the dashboard?
Old 03-04-11, 12:14 PM
lexus114
lexus114's Avatar
Fleabay?? Hahahahaha!!!
Old 03-04-11, 12:16 PM
jfelbab
jfelbab's Avatar
Learn to live with it. Any abrasive product will change the texture and/or patina of the dash and make it appear worse. If it really bothers you take it to a leather repair service.
Old 03-04-11, 01:09 PM
mandyfig
mandyfig's Avatar
I am not kidding I have 2 gallons of that thing. I wipe AS303 on everything...LOL!
Old 03-04-11, 02:57 PM
infinirx
infinirx's Avatar
I wonder if this stuff will help with that white dust that comes up from no where when using the heater at all (I can't get this fixed by the dealer). Not to go off topic.
I also have a small crack but a bit higher up and right near the trim of where the A/C grill is.
Quick Reply: Crack in the Dashboard!!!
