2008 rx 350 rear window wiper
Old 06-24-09, 06:24 AM
TvS
TvS's Avatar
Default 2008 rx 350 rear window wiper
Can't seem to lift the rear window wiper when cleaning window?
Old 06-24-09, 07:15 AM
salimshah
salimshah's Avatar
Use soapy water [soap safe for car finish] to soak the wiper edge. Do not operate the rear wiper as the edge has bonded with the glass, till it is free. Be patient and work it till it is free. You may have to get a new blade refil.
Luke warm water may also help to dissolve what ever is acting like a glue.
Edit: This does not seem like the problem.
Salim
10,9,8,7,6.5
Old 06-24-09, 09:54 AM
mandyfig
mandyfig's Avatar
Trying to understand this like Salim did...
The rubber is stuck on the glass, as Salim assumed?
Or are you asking why you can not fold up the wiper arm?
Old 06-24-09, 11:29 AM
mws4ua
mws4ua's Avatar
Subscribed.
The wiper on our car won't bend up for cleaning, either. (The second scenario noted by mandyfig.) I've looked at the wiper and it appears that it's just not meant to bend up like the front ones do. I'm just wondering if this is normal.
Old 06-24-09, 12:34 PM
salimshah
salimshah's Avatar
So ... one can lift it up, but it does not have lock position ...
Reminds me of complaint reported here .... member was upset that the front wipers had a lock position. He had the wipers locked in the up position and lifted the hood up ... damaging the paint at the edge of the hood.
I guess removing the lock position of the rear wipers does not address this problem.
It does remove the possibility of a nasty poke in the eye, if some one walks close bye and the rear wiper is locked in away position.
Salim
5,4
Old 06-24-09, 12:45 PM
TvS
TvS's Avatar
I want to have it lift up similar to front wipers on 350 and rear wiper on RX 300. Possible?
Old 06-24-09, 01:08 PM
benzo555
benzo555's Avatar
The rear wiper cannot be lifted much. I think it comes up like an inch. I think it took me like 5 minutes to change the refill.. worst refill to change..
Old 06-24-09, 04:46 PM
Grumpa72
Grumpa72's Avatar
Originally Posted by benzo555
The rear wiper cannot be lifted much. I think it comes up like an inch...
True, but there is a plastic piece that hides the hinge on the rear wiper. Careful examination will show that it only snaps on. Again, carefully prying the prongs off will allow the wiper arm to lift completely up and makes the installation of a new blade a piece of cake.
Old 06-24-09, 06:00 PM
hesham1
hesham1's Avatar
how careful? will a flathead screwdriver work? do you have a picture available
Old 06-24-09, 06:15 PM
salimshah
salimshah's Avatar
One can always use a plastic/rubber door wedge to prop it up partially.
Salim
5 4 3
Old 06-24-09, 06:25 PM
donmatt
donmatt's Avatar
Changing the wiper blade refill is a piece of cake. Just lift the piece of plastic located at the base of wiper arm up and remove. The blade will lift up and make the blade refill easy to replace. I just replaced mine. It took about two minutes from start to finish. Good luck.
Old 06-25-09, 02:31 PM
mandyfig
mandyfig's Avatar
^^Ditto, just practice and be careful with trying to pry the end cap off.
Old 06-25-09, 03:02 PM
TvS
TvS's Avatar
Thank you.
pbm317
01-22-13 02:15 PM
hlb
12-19-08 11:50 AM
RXGS
09-08-07 08:47 PM
Nidan
07-26-07 03:57 PM
Daddy-O
RX - 1st Gen (1999-2003)
01-02-03 07:28 AM
Quick Reply: 2008 rx 350 rear window wiper
