RX 330 power window question
Old 01-15-08, 08:19 PM
motiv8rnc
motiv8rnc's Avatar
Red face RX 330 power window question
if you ever look at your power window switches at night you will notice a green light on them. well my two front windows work fine from the drivers side master switch, as well as the rear driver side window. but the rear passenger side window stoped working off the master switch... the window works fine from its own door switch but its green light is blinking. what does the blinking mean? it does two blinks then a pause, soo on and soo on. anyone have a fix for this.
Old 01-15-08, 08:32 PM
mandyfig
mandyfig's Avatar
Need to re-set I think. Where is the re-set procedure for the windows? I think it is in the manual....
Old 01-15-08, 09:11 PM
motiv8rnc
motiv8rnc's Avatar
i cant find my owners manual... if anyone can post the how to on that it would be much appreciated... thanks
Old 01-15-08, 10:11 PM
CK6Speed
CK6Speed's Avatar
Roll the window down all the way and hold the button down for a second. Roll the window up all the way and hold the button up for a second. Done.
Old 01-15-08, 10:13 PM
grouch
grouch's Avatar
Look next to the phone. Someone thought it was a phone book.........
Reset:
1. push each door switch down and lower the window to half way.
2. pull up on the switch until the window is closed and hold it for a second. Done.
Old 11-01-08, 09:56 AM
kimono1
kimono1's Avatar
Thank God for this forum. I had the same problem and I was told to change the main window switch ($750).
Old 09-28-09, 06:34 AM
RX4Lily
3rd Gear
RX4Lily's Avatar
Have same problem and your solve it.
Thank you
Old 02-17-11, 07:54 AM
ffrana3
ffrana3's Avatar
Had same problem after having car serviced, worked for me, too.
"Roll the window down all the way and hold the button down for a second. Roll the window up all the way and hold the button up for a second. Done."
Old 04-05-14, 10:19 AM
H2OMONTE
H2OMONTE's Avatar
The reset technique looks very helpful but each of them says to roll the window down to start the process. My rear windows are stuck closed!!
Old 04-05-14, 04:39 PM
Rainbird
Rainbird's Avatar
Maybe the rear windows door lock switch is on. It's just forward of the driver door window controls. (rear window diagram with an X through it).
Old 04-05-14, 04:49 PM
RX330inFL
RX330inFL's Avatar
You may find something of use here:
https://www.clublexus.com/forums/rx-...-controls.html
socalturbo
06-17-23 06:14 AM
Cobra611
08-10-18 09:05 AM
momof1
09-12-17 04:41 PM
UNOHOO
RX - 1st Gen (1999-2003)
07-14-09 12:10 AM
bfigard
12-07-07 03:34 PM
Quick Reply: RX 330 power window question
