My MPG is LOW
Old 08-15-07, 05:50 AM
cheap_deal
cheap_deal's Avatar
Default My MPG is LOW
i own a 2007 RX 350 and the best i ever got was 17mpg (50% city 50% highway)
i use 95 octane fuel and my car has run 6250 miles.
i bought it new and followed the lexus recommended run in procedure, kept the revs low and didnt go too fast.
thought the mpg was low cause its usually driven fast, but have been staying below 70mph all the time and its still low!!
all the routine service has been done at the dealer and they too dont have an explanation as to why its low.
any ideas? im in the middle east and its hot here, but will that cause this big a difference when most RX350 owners get 22-23mpg??
Old 08-15-07, 07:37 AM
mandyfig
mandyfig's Avatar
17 MPG with 50-50 highway and city is low. Not surprising, but low. If it were all city...still you should hit 20's. Too rich maybe?
Old 08-15-07, 12:54 PM
Orzel
Orzel's Avatar
Middle East - heat, and fuel quality could very well be the causes of low mileage.
Old 08-15-07, 03:42 PM
Lil4X
Out of Warranty
Lil4X's Avatar
I don't recall the Emirates as having much in the way of hills, but I found that a few small things can add up to a pretty drastic effect on fuel consumption.
First, if you can drive with a rather constant throttle opening (holding a steady foot and disengaging the cruise control) you can make a considerable difference - on the order of 3-4 mpg. The Lexus cruise control is very rigid about maintaining your speed at the setpoint no matter what. This can lead to heavy acceleration on hills just to maintain speed, rather than letting a couple mph bleed off when going uphill.
The chemistry of your fuel seems to make a difference in my experience as well. The E-10 blended fuels (10% ethanol) deliver a bit over 2 mpg fewer miles than straight pump gas. There simply isn't the energy available in ethanol that there is in gasoline and it simply takes more of it to deliver near-equal performance.
Finally, the grade of fuel seems to have a bit of effect on mileage. I find that the extra 20 cents per gallon I pay for premium approximates the improvement in mileage over regular, making the cost per mile a wash. Quicker throttle response is a bonus.
If after 6K miles your RX is delivering poor mileage, try pulling the FI fuse or simply remove the negative battery connection for about ten minutes. This will cause the engine computer to reset and begin re-learning your driving habits. Give it a few hundred miles and check your fuel consumption again.
When all else fails, consult your dealer
Old 08-15-07, 11:57 PM
AM1
AM1's Avatar
i only get around 14-15mpg on 87 octane
Old 08-16-07, 12:31 AM
TunedRX300
TunedRX300's Avatar
You may try different fuel, gasoline formulation change over time and region.
Also try 0w-30 synthetic oil such as German Castrol, protects the engine at hot temperature but better flow before reaching operating temperature.
Old 08-16-07, 12:55 AM
cheap_deal
cheap_deal's Avatar
i have never used the cruise control, always a steady foot.
there are absolutely no hills here, its completely flat.
i use 95 octane fuel, i do know there is a high sulphur content in the fuel here and thats why we dont get the GS350 here as they cant run on the fuel here.
Old 08-18-07, 01:40 AM
ricdiablo
ricdiablo's Avatar
Maybe the air conditioner? Try switching to Auto and set it to 77-78 and see if that helps.
Old 08-18-07, 03:34 AM
cheap_deal
cheap_deal's Avatar
it is always on auto with recirculate and temp at 75 F. if i increase it to 78 its gonna blow hot air!!!
Old 08-18-07, 08:20 AM
cheap_deal
cheap_deal's Avatar
also what tyre pressures are you guys running?
Old 08-18-07, 12:03 PM
mandyfig
mandyfig's Avatar
33 psi, front and rear.
Old 08-18-07, 02:29 PM
ehizon
ehizon's Avatar
if youre in the middle east, shouldnt be petrol be very cheap over there? (if its cheap why worry about mpg?)
Old 08-18-07, 03:03 PM
mandyfig
mandyfig's Avatar
I was going to ask the same thing. He's just worried the car is not performing as it should be?
Old 08-21-07, 11:11 AM
The G Man
The G Man's Avatar
Why use 95 octane?
Old 08-21-07, 11:25 AM
cheap_deal
cheap_deal's Avatar
well just concerned if there is something wrong with the car, otherwise i dont care if its 10mpg or 20mpg fuel is cheap.
@gman, most gas stations have 95 as the lowest grade!!!! though i have seen a few with 91 also, nothing lower.
Quick Reply: My MPG is LOW
