View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
Old 06-01-07, 04:33 AM
  #211
ricdiablo
ricdiablo's Avatar
I don't recall the RX manual requiring a minimum octane. What it said was use Premium Gasoline Only. If I am not mistaken, for Japanese cars imported into the US, mid-grade or higher is considered premium (89+). I know for my BMW, which was a "Premium Gasoline Only" vehicle, the manual specified the minimum octane to use as 89. That car has lasted me for 12 years with no problems.
Old 06-01-07, 05:25 AM
  #212
jmaynard
jmaynard's Avatar
I quoted the 2007 RX350 manual earlier in this topic. It specifically says 91 octane.
Old 06-01-07, 08:25 AM
  #213
ricdiablo
ricdiablo's Avatar
Then as my 10-yr old says:
"DARN RIP-OFF ARTISTS!"
Old 06-01-07, 11:01 AM
  #214
AM1
AM1's Avatar
yawn.......anyways rx330s dont need 91. if ihad a 350 i would still put 87 in it. the dealer said its ok also. but i guess they dont know anything
Old 06-01-07, 11:47 AM
  #215
jmaynard
jmaynard's Avatar
Funny...my dealer (Lexus of Wayzata, in the Twin Cities) made a point of telling me to run 91 because the manual said to.
Old 06-06-07, 09:05 AM
  #216
NewEngland
NewEngland's Avatar
Default Alway Use The Premium 93 gas....Knock & pinging noise still
Hi All-
I alway use the premium 93 since i had my RX. I still get some the Pinging noise when the speed is under 35mph. The noise will be worse with regular gas. This just happen after the engine has warm enough. Sometime it's disappeared and come back anytime.
I did check the engine oil, Transmission fluid, coolant, and used a bottle of Fuel system clearner from Chevon. My temp gause showing 45% after finish the warm up. I got between 14-15mpg (city only). I drive about 4 miles (one way)with heavy traffic jam everyday that it took my about 25-35min.
Please give some advice before i go to the dealer. I just worry when i bring to them the ping sometime disappear.
Thanks everyone in advance.
Old 06-06-07, 09:17 AM
  #217
VroomVroom
VroomVroom's Avatar
I definitely recommend taking the car in...there's something wrong. I'm guessing the CEL isn't illuminated, which is a bummer, but there are still some diagnostic steps they can take. This could be a fuel, spark, or even emissions issue, but it's definitely not something you should be encountering. Good luck...
Old 06-06-07, 09:22 AM
  #218
Lexmex
Super Moderator
Lexmex's Avatar
Pull the battery cables for a few minutes, then reattach and drive for about 15 minutes. I find doing this solves a lot of drivebility problems with my RX300.
Old 06-06-07, 09:25 AM
  #219
NewEngland
NewEngland's Avatar
I forgot to mention about miles on my car. i did maintaince very on schedule. It's RX 330 2004 with only 38K...
Old 06-06-07, 09:27 AM
  #220
NewEngland
NewEngland's Avatar
Hi VroomVroom- what is CEL?
Old 06-06-07, 09:39 AM
  #221
VroomVroom
VroomVroom's Avatar
Check Engine Light. Usually indicates an OBDII error message - very helpful in diagnosing a problem. Good advice on pulling the battery connections, but I'd still have it checked out. Detonation is never a good thing.
Old 06-06-07, 10:54 AM
  #222
AM1
AM1's Avatar
maybe a bad o2 sensor?
Old 06-06-07, 10:58 AM
  #223
Lexmex
Super Moderator
Lexmex's Avatar
bad 02 sensor would throw the cel
Cars down here get pinging during summer months, when it gets hot and even worse we have less oxygen at this altitude, so the effect of the heat gets really amplified.
Old 06-06-07, 11:22 AM
  #224
biff44
biff44's Avatar
Are you are sure you are hearing Pinging, instead of some sort of valve noise? When you are driving below 35 MPH, you are not putting too much load on the car, and it should not be pinging.
Pinging is a little hard to describe, but it is a little like a person with allergies trying to clear phlem out of their throats--a grinding uneven sound.
On cars that I have had that ping, like an old avalon, it would only do so when I floored it going uphill.
Old 06-06-07, 11:59 AM
  #225
jfelbab
jfelbab's Avatar
I'd caution you to know what your doing if you remove the battery cable. You will have several minutes of system resets to do after removing the power. You need to reset all of your power windows, rear hatch, sunroof, etc., etc.
Quick Reply: Do you need Premium Gas in the 2RX (merged discussion threads)
