List problems you had so far with your RX330/350
Old 01-03-14, 11:57 AM
  #61
Rainbird
Rainbird's Avatar
Originally Posted by Melody143
- always have a problem with the low tire pressure light coming on when the pressure is not low.
Did you check the pressure in the spare tire? Nine times out of ten the spare is the problem.
Old 01-03-14, 04:46 PM
  #62
ISFWes
ISFWes's Avatar
Default Problems
I bought my FWD 2007 RX350 new off the lot. About a year later it had the only recall for the oil line done.
No more problems after that. About a month after my extended warranty kicked in. My XM radio receiver died. That was replaced. Then about a year later I got an airbag warning light. The drivers side pillar one went bad. Took the dealer about 10 days to get one and install it.
Sold it last summer for 25k with almost 70k miles on it to CarMax. Excellent car.
Old 01-06-14, 06:47 AM
  #63
Campy6178
Campy6178's Avatar
Unhappy Oxygen Sensors
Check engine light along with VSC came on this weekend and it turns out I have a bad O2 and an air-fuel ratio sensor. I'm fortunate enough to have a mechanic in the family that can replace these for a little more than $400. Problems like this make me wish I had purchased a different vehicle
2007 RX350 with 74,000 miles
Old 01-06-14, 09:28 AM
  #64
1WILLY1
1WILLY1's Avatar
wow I had no idea these RX's were so problematic.
Old 01-07-14, 11:28 AM
  #65
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ..............
That is way too much money for the b1s1 sensor job.
The Denso sensor is only $94.00 shipped from ebay and your mechanic should not charge more than $100.00 to get it installed.
Old 01-07-14, 04:09 PM
  #66
sgmstr
sgmstr's Avatar
04 RX330 FWD. a cover on the outside door handle came loose a few months ago. instead of pulling out the entire door panel as suggested below, I tied fishing line to the lock assembly and pulled it back after i tightened the entire door handle. It took less than 5 minutes and super easy.
Old 01-07-14, 04:54 PM
  #67
Rainbird
Rainbird's Avatar
The RX's are not problematic. Most all cars will have some problems that need fixing. I am a older guy and my RX is one of the most reliable cars I have ever owned. The question asked is "problems you had so far". There are only 66 postings here of cars that had problems worth commenting on. People that don't have problems don't post on this thread!
Old 01-08-14, 06:18 AM
  #68
gasconguy
gasconguy's Avatar
True above. There are tons of these vehicles out there; some are bound to have issues.
I just got mine, and I took it through the car wash and the sunroof leaked slightly. I don't know if the calibration helped but I did it after the car wash, so we'll see...
But the rear hatch also leaked, quite badly. I read on this site that the brake light could be the issue, but not sure how to diagnose that... anyone have experience with that?
btanchors
Automotive Care & Detailing
30
06-25-19 12:45 PM
DanBryant
ES - 6th Gen (2013-2018)
61
02-20-18 04:30 PM
angela9051
12-24-17 08:04 AM
Rob_Rx330
06-30-05 09:40 PM
IsNYC
09-29-04 01:08 AM
Quick Reply: List problems you had so far with your RX330/350
