RX330 Sport Equipment
I'm looking to improve my 2004 RX330 suspension.
Especially the excessive nose dip on hard braking and some body roll.
Improved shocks appear to be the easiest starting point.........
I owned a 1999 Acura TL and had similar problems.
I upgraded to the 2002 TLs (sport) and performance improved dramatically.
Any suggestions on maintaining a decent ride while improving the RX handling?
Any specific items or locations for sportier RX330 equipment?
Regards
Regards
Originally Posted by thwang99
How do H&R's compare to Tanabe and Eibach pro-kits?
- Tony
- Tony
Super Moderator
Last time I emailed Tanabe a few months ago they did not have anything available for the 04+ RX330 even though some places list it as such. It seems like H&R and Eibach are the only readily available springs for us. I ordered H&R from Tire Rack but they set me a set of Eibachs instead so that is what I have on my 04. Handling wise you definately can feel the difference. Less body roll and a bit stiffer. Not bad at all though even with my 20" rims. As for lowering, the front is somewhat noticeable, but the rear you can barely tell it was lowered at all. Measured wise it came out to maybe 1/2" while the front got about a inch or so. Compared to a stock RX330 you can tell, but looking at it by itself you wouldn't know it was lowered at all. I guess going from a 4" gap to a 2.5-3" gab doesn't really do much for the eye. Hopefully one of you can try H&R and show us how it lowered the RX330 because I don't want to switch if the H&R doesn't do much better or if full adjustable coil overs come out soon.
The 2000 TL is a great car.
I'm not sure what they did between my 1999 and the 2002 TLs but the
ride was the same and it handled much better.
Are you guys saying I should try the H&R short springs without updating the shocks?
It's fine by me, but thought the two went hand-in-hand. Thanks for the link to the Tire Rack.
I've just installed their Bridgestone H/L Dueler Alenza's on my RX 330 and the wife's
Highlander. These have to be much better in light snow than the original tires that were
scary. First time in rain with these new tires I felt very comfortable. Nice change, a bit less
sway (stronger side walls?) and just a spec more road noise but a great trade-off.
So try the springs first..................
Anybody else try wringing more performance out of the '04 RX 330 ?
Regards and thanks for the feedback.
I appreciated the link and info. Found a local Acura, Lexus performance house.
He suggested one step at a time beginning with the H&R sport shocks. The shorter
springs will put some tension on the shocks and limit range of motion. If the
Lexus Rx330 only has 40k miles he suggests to do the shock and spring individually.
The coil over deal might be a bit more aggressive and expensive.
He likened them more to small, low ground, street racer type application.
I really don't know but at least this business owner isn't steering me to the highest cost
items initially.
Thanks again for getting me going in a straighter path.
Regards
items initially.
Regards
Just keep in mind that if you decide to upgrade shocks later, you have to pay for the labor and 4 wheel alignment again. The shop obviously does not make $ off parts, be careful they have incentive to make $ off labor. The shop owner is right that stock shock may wear out a faster but probably have lots of life left. It is all up to you.
Super Moderator
I've been running my Eibacks on the stock shocks since about 38K miles. I have abouty 42K now. So far so good. I've run Eibachs on stock shocks on other cars before and had no problems for at least a good 50K miles. The Eibachs and H&R are claimed to work with stock shocks. They are stiffer, but not too much so. If you are handy doing things yourself and have the tooks you might be able to do the spring swap yourself. I was able to swap my Eibach's onto the stock shocks and reinstalled all within 3-4 hours in my garage working by myself. The alignment still needs to be done my a shop though.
I'm very encouraged by these helpfull posts.
I've told the installer to buy the sport shocks and call me with date.
I'm open to other performance modifications and will evaluate
this performance shop's first step.
I have changed the spring to Espelir sport spring, along with the stock shocks. Performance improved alot, plus I found that this springs lower the car more than H & R or Eibach. As i remember the website shown it lowers 55-60mm, which is around 2.5 inches. Makes my car looks better now, as I'm running 20" wheels. The rear spring does the job, it's hard enough that can remain the similar height even 3 people sit at the back with luggages.
Super Moderator
Chris
Hi PPMYIP,
How's the ride quality after you install the springs? I assume if they lowered the car for 2.5" with stock shocks they gotta be super-stiff in order to maintain the load rate. How many miles do you have them on the car so far? Did you notice any leak on the shocks (assuming they are oil-filled).
Man I wish Tein has coilovers similar to the CS or wagon series for the RX400h.
Hi Chris,
I bought that spring from Hong Kong, originally I was going to get Tanabe GF210, however they are out of stock and need to wait, therefore I take Espelir. You may check if there's any distributor in US or if any shop can bring them in.
Patrick
Patrick
