Voice Commanding Temperature
Is there a problem in the RX with changing the temperature? Whenever I go to the command list, "climate" is always grayed-out. ON the GS you can say "72 degrees" and it sets it but on my RX I've tried a little bit and it doesn't work. Am I doing something wrong? Is this feature deactivated on the RX?
2005 RX w/ nav...
Thanks!
2005 RX w/ nav...
Thanks!
Try command Help. It will take you a help menu and one of the sub menus is a set of all available voice commands. This comes in VERY handy.
And guess what...under the Help menu, the climate options are GREYED OUT on my 05 TC RX330. I think this is a pretty solid answer to the question. It seems they are completely unavailable.
Originally Posted by jayskinner
Since you have to press a button anyway to activate voice command, why not just press and hold the top or bottom of the temp button until you get to the desired temp.
taylorjste
06-02-07 06:20 PM
