DIY oil filter change 2005 RX330...Pictures!
Old 04-03-08, 07:04 PM
  #31
steiner
steiner's Avatar
http://us.lexusownersclub.com/forums...pic=21979&st=0
Read this for a very detailed procedure.
Old 04-04-08, 10:23 AM
  #32
sama
sama's Avatar
Has anyone used this product before.
Oil Extractor
Skymall claims this is how Mercedes-Benz factory technicians are trained to change oil by extracting oil through the dipstick tube, Is this true?
Attached Thumbnails DIY oil filter change 2005 RX330...Pictures!-102152387x.jpg
Old 04-07-08, 01:53 PM
  #33
wmb
wmb's Avatar
I actually have this oil exactor for my BMW. It's so easy and since BMW oil filter is on top as well, it's great.
Although the oil filter for the RX350 is different, but it would locate on the same spot as the RX330, is that correct ?
Thanks
Old 04-08-08, 12:41 AM
  #34
erick3
erick3's Avatar
...Lexus of Seattle uses mobil 1: 5w-30 fully synthetic blend...do all dealerships do that?
...because you shouldn't be using an oem filter w/ any synthetic blend...not enough filtration...!!!
Old 04-09-08, 07:06 PM
  #35
LexTodd
LexTodd's Avatar
Default Synthetic Blends and Synthetics
Erick3- I think you mean Mobil 1 full synthetic 5w30. This is a popular choice for Lexus/Toyota as Mobil makes their oem stuff. However, blends may not be what they seem. At present there are no regulations governing blends! Some of the smaller oil companies are touting their products as blends--this is often because they use Group I base oils(cheaper, less pure) and need some synthetic to make spec! Larger companies may use their standard Group II base oil and add 10% synthetic to make a blend--There are small advantages but usually not worth the price. Full synthetic oils are all very similar (with an exception or two) They are made with Group II+ or GroupIII base oils (highly refined, very pure,but still petroleum based) and a synthetic additive package. Full synthetic oils are very similar--they have two major advantages. Faster oil delivery at cold start and their ability to maintain viscosity at high temps. Don't buy into the extended drain capabilities of synthetics--change your oil at regular intervals--abide by your owners manual! As for the oem filter not being compatiblewith synthetics--that's just not true! (sorry for the long post-I'm bored)
Old 04-11-08, 04:19 PM
  #36
cdnewton
cdnewton's Avatar
Oil Extractor
I have the same extractor .... I got it from Griot's Garage .... it works great. As for the oil extractor, I use it every other oil change and it is really convenient.
BTW, I have a Fumoto valve on and love it also.
Old 04-12-08, 12:40 PM
  #37
UZ214
UZ214's Avatar
where is this filter? i just took the smaller covr off and i only see the oil drain plug dont see the filter anywhere, ..
Originally Posted by Lextranny
Here is the oil filter replacement in place. Part # 90915-YZZD1. Made in Thailand.
Notice there is a oil funnel (very smart!) oil will drop directly down to your dirty oil container.
Old 04-13-08, 11:18 AM
  #38
steiner
steiner's Avatar
Better instructions and pictures here:
Old 04-14-08, 11:16 AM
  #39
UZ214
UZ214's Avatar
yup got it, thanks!
Old 09-06-10, 01:33 PM
  #40
LexFather
Guest
Posts: n/a
Changing my RX400h now and searched and this thread answered my questions. Thanks again!
Old 06-19-12, 06:06 AM
  #41
genebolick
genebolick's Avatar
Thanks for posting - great procedure.
Just did my '05 RX330 and it went like a champ. Didn't need 5 quarts, though, somewhere around 4.5.
Old 06-20-12, 07:57 AM
  #42
lexus114
lexus114's Avatar
Hate to say this dude, but it takes 5qts. exactly.
Old 06-20-12, 08:54 AM
  #43
howdybob22
howdybob22's Avatar
Yep, that's why it was always cheap and convenience for me to buy the synthetic 5 qts. jug - Nothing left/extra until next oil change
Old 06-20-12, 12:54 PM
  #44
dcdyd
dcdyd's Avatar
However 08 350 requires 6.4fts. I don't know why it is such big jump from 330.
Old 06-20-12, 01:04 PM
  #45
HtownBlue
HtownBlue's Avatar
Bigger pan and larger oil pump and larger engine all combine for need for more oil.
Quick Reply: DIY oil filter change 2005 RX330...Pictures!
