Rear Antenna Motor
Old 10-19-16, 01:39 PM
lexrally
lexrally's Avatar
Default Rear Antenna Motor
Hi Forum
Where can I get the little motor in the antenna pulley system?
I think it must be burnt out, I just replaced the antenna mast recently.
Old 10-20-16, 05:49 PM
aznlapin
aznlapin's Avatar
The entire assembly is 86300-0W030, motor is not sold separately as that is the main part. You can see the parts here: CLICK ME
You can get it at the dealer but ebay and Amazon has it in stock as well.
My mast's nylon cord snapped last year so I just left it as is. I have the mast halfway up (naturally slides down by itself) and radio reception is fine.
Old 10-27-16, 08:38 PM
shervink24
shervink24's Avatar
I got my RX as a gift with 170K miles. There's a lot of little things to fix. The antenna was being rotated and adjusted by hand until the motor took the antenna up or down. With the motor blown and the antenna up the radio service should be fine. To fix the issue completely all the parts can be found on ebay for cheap. Be careful what part you order because some of them may not be a one to one fit, and will require a small bit of customization to fit. If you dont hear a winding noise, or motor noise when you turn the car off and on from the back then the antenna motor is blown. The antenna and motor are 2 separate parts.
Old 10-30-16, 03:55 PM
Boypony
Boypony's Avatar
Easy job and the masts are cheap. I'd be amazed if your motor is really burned out.....check connections.
rclab1
05-03-13 12:30 PM
GWS
GS - 1st Gen (1993-1997)
02-28-11 03:59 PM
horent135
SC- 1st Gen (1992-2000)
02-13-11 09:31 PM
JOHNBRAY11
04-13-10 07:45 PM
Quick Reply: Rear Antenna Motor
