01 RX w 38K miles steering wheel noise
Hi everyone
I just bought this car and I notice there is a clicking noise
coming from the steering wheel area whenever I turn the wheel
Left and right
It does not sound like the creaking noise I know the RX is known for
The dealer is sayng it is a steering column Issue and I can replace it if I want
My service advisor tells me it is not a safety issue
Has anyone had this " clicking " noise ? Anyone replace the entire
Steering column ? The dealer want $1400 and I am thinking of passing
Left and right
Hi car guy
My understanding is if is the spiral cable , it usually means you have no horn , the electrical including most light controls would also be out
I don't have that issue other than the " clicking " when I turn left or turn right with the steering wheel
I did lube the floor joint though when it was creaking and that stopped but now the clicking started
One needs to narrow down the source of sound ... quoting another member ,,, "use your ear *****". For a few $$, you can get a mechanics stethoscope and trace the source based on the intensity of the sound. Other than ears, you can touch and feel the click and at times visually see the jerky movement.
Please narrow it down to: Steering wheel, floor, engine compartment (steering pump, rack), wheel links.
Only then we can speculate more accurately.
Salim
Salim
Tx guys
I might bring it to another mechanic for a second opinion
You would think the Lexus mechanic would know considering how much they get paid
The diagnosis from them is the lower shaft and the intermediate joints are getting worn
Ah, the o'l click, I took off that access cap on the side of the steering wheel and sprayed that silicone lubricant in there, turned the wheel back and forth, even sprayed on between the steering wheel, did it for about 15 minutes and it was gone, did this about a year and a half ago and still no noise. (Be generous with the silicone lubricant, spray every 2-3 minutes)
Humm
The only worry is spraying lubricant in the airbag area sounds scary
Has anyone had this clicking sound ? The sounds is not a moaning or creaking
But a " clicking sound "
I have a steering wheel noise too. Mine sounds like metal scraping lightly against plastic. It also makes a secondary noise that sounds like rubber or plastic rubbing against glass or a smooth surface, kind of a like a squeak.
I doesn't always make this sound but often does. I'm also used to it now so I don't notice it.
does it sound like a squeak? My 01 was doing that, theres a boot looking thing by your pedals, its rubbing on that. I never cared to fix it, i heard I was suppose to spray some lube on it.
https://www.clublexus.com/forums/rx-...and-video.html
purebliss
ES - 5th Gen (2007-2012)
10-09-06 08:28 AM
