New codes after repairs...
To start, I want to start by saying you guys Rock! Thank you so much for helping me through my issues. Especially Salim and Fastnoypi, I certainly would have given up after the first hour without your patience and valuable help.
I replaced my knock sensors and harness, AF sensors, plugs, coil packs, valve cover gaskets (both were dried out and leaking), pcv, cleaned my maf and air filter and my RX is running like a dream, with full-time rather than intermittent OD.
My problem now is that after 60 miles my CEL came back on. I took it to Autozone and got the codes for lean combustion ratio: 0171 and 0174. I did notice on the way to Autozone that I was getting some pinging on hills and when accelerating to pass.
Has anyone else encountered this issue after the repairs I listed. If so, could you tell me what it took to resolve your problem or give me a troubleshooting path to get me started?
Again...Thank you SO much for all your help there is NO way I could have done it without you, and it is so good to have a greatly improved knowledge of my vehicle, it's engine and it's systems. The experience, though it took me forever (I could do it again in half the time or less) was pure gold.
Kind Regards,
Russ (Jacklalanne)
Kind Regards,
Russ (Jacklalanne)
Z07: You nailed it~*
I am embarrassed to say that at the end of a long day I had forgotten to tighten any of the three clamps. Tightened now and no CEL or pinging.
I have sort of been holding my breath and waiting to re-install the tray and wiper hardware. I have seen a few posts by members that have done the same repairs and had the cel come back on shortly thereafter throwing the same codes for the sensors. Wondering now if I should go ahead and finish up or wait a couple hundred miles. It is running so nice now I am definitely tempted to call it good and button things up.
Thank you so much!
Thank you so much!
A few people forget to put the hose back on the PCV when they take the intake manifold off. I'm assuming you attached the booster hose since that one is pretty obvious
A new CEL code...
I am now getting a P0420 code and since it is still so close timewise to my knock sensors, harness O2 sensors etc work I am suspicious that it may have something to do with that work. Does anyone have any thoughts on what I may have left loose to cause this. I have put 700 miles on since doing the work so I'm definitely not ruling out it being completely unassociated with that project. Thanks in advance. Russ (Jacklalanne)
Good luck!
I got that when one of the exhaust system donut gaskets started leaking. I had heard it when i was next to a wall but ignored it until it threw a code. The dealer wanted to replace the cat. I told them to just change the gasket. They reluctantly did it. I think it threw the code one more time and then never again.
Thank you...
Fastnoypi and maxSteel...I will check those components tomorrow morning when I get off work. The O2 sensors came with anti-seize on the threads so I will check them for snugness as well as all the exhaust clamps etc. There are no audible leaks that I can hear over the normal engine noise but I'm sure that doesn't necessarily mean much. Thank you so much...
P0420 code
Life (work around the house) has interfered with my plans to check this out up until yesterday. I was pretty sure it was going to be a matter of the O2 sensor having backed out, but it was good and tight still. Since it is the 420 code only and not the 430 I am thinking this must narrow it down to a few components. Any thoughts about which ones it could be and how I can best go about testing for them? Thanks in advance for your help in bailing my butt out once again.
Kind Regards,
Russ (Jacklalanne)
Kind Regards,
Russ (Jacklalanne)
