How can engine oil end up in intake
Old 06-16-16, 11:20 AM
  #46
fastnoypi
fastnoypi's Avatar
Originally Posted by Drcoffee
I don't think the slung oil is really the issue unless the vacuum is so strong it draws the oil up under the baffle. I think the Gen2 and Gen3 are better suited to screen out the oil. The PCV valve is in the upper left corner of the baffle.
Thanks for posting a 1st gen valve cover. The Gen3 is vastly an improvement.
Slung oil is the issue combined with short driving periods where oil cannot get hot enough to steam out any moisture. The cooler oil gels and condenses inside the baffle area of the valve cover creating a high pressure situation internally which the vacuum can draw oil from.
If you have oil consumption issues, its best you minimally pull off the rear valve cover and clean out the baffle if you don't want to spend on a 3rd gen cover. I would be hesitant to just pour seafoam or any top end cleaner through the pcv area to clean the baffle, doing so my dislodge sludge into the head.
Comparative pics of 2nd and 3rd gen covers are on post #14
nan88
01-01-21 07:58 PM
abs
05-02-19 08:15 PM
dude74
16
04-08-02 01:43 PM
jdaste
Maintenance
11-25-01 05:28 PM
Quick Reply: How can engine oil end up in intake
